replacing front wheel bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dofrazie, Nov 23, 2011.
  1. Nov 23, 2011 at 11:14 AM
    dofrazie
    dofrazie [OP] New Member
    David
    Tennessee
    05 PreRunner 2wd
    I'm having my front Wheel bearing replaced they are telling me i have to replace the hub. Can someone tell me why?
  2. Nov 23, 2011 at 11:44 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Sorry can't help you - subbing for same info.
  3. Nov 23, 2011 at 11:47 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    It's a unit bearing assembly that has to be pressed in. There are threads on this site outlining the steps to do it yourself if you have a 20 ton shop press at home.
  4. Nov 23, 2011 at 12:08 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I got my hub and bearing assembly for $40 on eBay with a lifetime warranty
  5. Nov 23, 2011 at 12:09 PM
    Overlander
    Overlander Well-Known Member
  6. Nov 23, 2011 at 3:40 PM
    dofrazie
    David
    Tennessee
    05 PreRunner 2wd
    Just got back home from spending all day at a Toyota dealer getting the driver's side front wheel bearings and hub replaced ($732.00). I had no idea what the problem was, or that it cost that much to do the job($225.00 parts and $437.00 labor). I will do the passenger's side my self, it looks fairly easy. Thanks everyone for the coments on this thread. My truck's symptom was a whining rotational noise. Last night it got so bad I thought I was going to have to pull the truck over. I had not noticed the noise before but after getting it done; there was a whin I was ignoring. All quite now!!! Thanks for everyones help!!!!!
  7. Nov 23, 2011 at 4:30 PM
    kimo
    kimo Well-Known Member
    Darin
    MONTEREY BAY
    07 TRD sport pre-runner
    Damn! thats an expensive repair for a frickin wheel bearing. Let us know how your do-it -yourself project goes. I plan on doing this too when the time comes, thanks
