Replacing Front Wheel Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wood, Aug 19, 2009.
  1. Aug 19, 2009 at 8:25 AM
    Wood
    Wood [OP] Well-Known Member
    Getting ready to replace a shot front wheel bearing in my '06 DC and wondering what 'specialty' tools I might need. Can someone tell me what size socket I need for the axle nut and anything else (tips/tools, etc) before I get into this.....thanks.
  2. Aug 19, 2009 at 8:26 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
  3. Aug 19, 2009 at 8:30 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Axle nut is 35mm.
    I'll be doing mine this week also. If you look at the Factory Service Manual it might give you an idea of what the process involves and what kind of specialty tools you'll need.
  4. Aug 19, 2009 at 8:35 AM
    drew02a
    San Antonio, TX
  5. Aug 19, 2009 at 8:39 AM
    Dark Knight
    Jeff
    NC/SC
    if bearings are being replaced its gota come out....
  6. Aug 19, 2009 at 8:41 AM
    drew02a
    San Antonio, TX
    The Axle? The nut would need to be removed, but you can leave the other end in the differential. The hub will slide right off of it once the nuts are removed.
  7. Aug 19, 2009 at 8:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  8. Aug 19, 2009 at 8:46 AM
    drew02a
    San Antonio, TX
    That's how most places sell them anyways. I picked an assembly up yesterday for about $100.
  9. Aug 19, 2009 at 8:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats a dam good price! Wher did you get it?
  10. Aug 19, 2009 at 8:50 AM
    drew02a
    San Antonio, TX
    O'reilly
    Hopefully the new bearings will retain the luck of the Irish :cool:
  11. Aug 19, 2009 at 8:50 AM
    Dark Knight
    Jeff
    NC/SC
    maybe i'm a little confused, I was going from the standpoint that the OP's bearings needed replaced (also in my head I know when I do mine I'll be doing both axles and bearings)
    wow $100 bucks is not bad...where did you get the assembly for that?
  12. Aug 19, 2009 at 8:52 AM
    drew02a
    San Antonio, TX
    Simul-post ^
  13. Aug 19, 2009 at 8:55 AM
    Dark Knight
    Jeff
    NC/SC
    haha I see that now.... we just got an O'reilly in my town. Sweet!
  14. Aug 19, 2009 at 8:59 AM
    drew02a
    San Antonio, TX
    Is that for just the bearing?
  15. Aug 19, 2009 at 9:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats good to know! I think Toyota wants close to $200.00 for them.
  16. Aug 19, 2009 at 9:41 AM
    Wood
    Is it a 12 pt socket? I thought I saw somewhere online it was 39MM....maybe not. Where can I download the service manual? Thanks again.
    Looks like the bearing is sold as a hub assbly. Ebay for about $100.00. Is there a cheaper place?
    Anything else anyone can add is appreciated...don't want to get it half apart and find out I need to make a run for more tools/parts and no way to get there!
  17. Aug 19, 2009 at 9:43 AM
    drew02a
    San Antonio, TX
    It's definitly 35mm. I pulled my front axles out about a week ago. Yeah, major car repairs are dicey when you don't have a second vehicle.
  18. Jan 18, 2010 at 9:55 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  19. Jan 29, 2010 at 8:14 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
  20. Jan 29, 2010 at 9:21 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    That part is the 4x4 wheel bearing/hub assembly, but it looks like the pre-runner uses the same part as the 4x4 (according to the fsm). Instead of the front axle passing through it, there's a "front wheel adjusting nut".
    So yeah, it's the right part...as far as I can tell. I've changed one on a 4x4 but not a a pre-runner so maybe someone else can chime in. You could always pull a wheel off and take a look to get a better idea of what you're dealing with.
