Replacing Fuel Pump on a 06 Tacoma
Discussion in 'Technical Chat' started by hgraham, Oct 13, 2014.
  1. Oct 13, 2014 at 4:33 PM
    hgraham
    hgraham [OP] New Member
    Washington State
    06 V6 Tacoma
    Stock TRD Off Road
    Just got the call from the service center and they want $1000.00 to install a new fuel pump. I found a posting about a 05 Tacoma with some valuable infomation. Sounds like the aftermarket pumps are better and cost less (lots less) and that the best approach is removing the bed vs dropping tank.
    Can anyone speak to this, I have basic tools, friends and some know how. Should I take this on or get fleeced?
  2. Oct 14, 2014 at 9:39 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I replaced mine by dropping the tank in my garage..... alone :D
    It was not too hard, basic tools. Some of the fuel neck connections were tough to get off as well as the connections on the tank itself, with an extra pair of hands it is quite easy.
    Run the tank as low as possible to make it lighter.
    I will recommend a strap wrench for removing the fuel tank cap.
  3. Oct 14, 2014 at 10:25 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    Should not be too bad, sent you a pm.
