Replacing gaskets and seals on an old cap
Discussion in '1st Gen. Tacomas (1995-2004)' started by savenelroy, Dec 15, 2015.
  1. Dec 15, 2015 at 4:24 AM
    savenelroy
    savenelroy [OP] New Member
    Rick
    98 Tacoma 2WD Xtra Cab
    My truck cap has been dusted off and put back on my truck after sitting behind my dad's garage for 8 years on cinder blocks. I bought it used about 11 years ago and have the original gasket that seals between the cap and the truck. Looking to replace it since it's misshaped and leaks. Also wondering if there should be a gasket between the cap and the rails of the bed liner that the cap sits on? I seem to be getting a little water in there too. Any idea where I should buy these gaskets/seals and specifically what kind? One size fits all?
    Also, the wiring that was tucked behind the bed liner is no longer connected to anything! I discovered this when I tried connecting the center light on the cap. I imagine at one point one wire was grounded to the truck and the other ran to a tail light?
  2. Dec 15, 2015 at 8:48 AM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    There's plenty of weatherstripping at auto parts stores or home improvement stores that can seal the rim of your truck. you just gotta get under the cap and remove the old stuff so you can put the new stuff on.
    as far as the wiring goes, ground the ground wire, and tap into one of the brake lights. just like you thought. see if you can find where it was originally tapped in.
  3. Dec 15, 2015 at 9:30 AM
    savenelroy
    Rick
    Cool. I will make that a weekend project ;) Any idea where I get a replacement for the gasket that snaps onto the cap and sits between the cap and the back window of the truck? That's where most of my water is getting in.
  4. Dec 15, 2015 at 9:48 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  5. Dec 15, 2015 at 4:34 PM
    savenelroy
    Rick
    That looks good for between the cap and the rails of the bed. I also need that thick rubber gasket that goes between the cap and the window.
  6. Dec 15, 2015 at 5:42 PM
    CodeSeven
    Serge.
    Coachella Valley
    Now that one. you'll have to cut off 1/2 of an inch of it, and take a pic of it sideways so I can see the molding design. that goes throughout the whole weather stripping.
  7. Dec 15, 2015 at 6:03 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  8. Dec 15, 2015 at 6:20 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    that's a little overkill. all you need is a thin strip to cushion the cap from directly contacting the rail and to give it a little water-resistance. you don't want a whole lot going on between it since it will get clamped down anyway
  9. Dec 15, 2015 at 6:46 PM
    CodeSeven
    Serge.
    Coachella Valley
    the op is already good with the first link you gave. i think that guy was suggesting what to use that for the space between the shell and the rear window. just google "camper boot" to find a selection
  10. Dec 15, 2015 at 6:48 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I've heard mixed reviews about the "between" moldings/gaskets and most won't be fully waterproof due to the movement of the bed :(
  11. Dec 15, 2015 at 6:49 PM
    CodeSeven
    Serge.
    Coachella Valley
    yeah, and it could rub off your paint.
  12. Dec 15, 2015 at 6:52 PM
    CodeSeven
    Serge.
    Coachella Valley
  13. Dec 15, 2015 at 8:36 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I've been looking for the "mega" size version of that clear tube thing (doesn't exist). would help keep the dam snow and ice outta my rear view :)
  14. Dec 16, 2015 at 6:42 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I replaced mine with gaskets from our local Topper King shop. They were exact fits. They're all pretty general. I don't remember what it cost but they were very reasonable, cause I'm cheap.
  15. Dec 18, 2015 at 3:34 AM
    smuook
    smuook Daily Driver "Plus"
    Smuook
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
