Replacing Hard Brake Lines
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VersaTrax, Dec 28, 2021.
  1. Dec 28, 2021 at 1:51 PM
    VersaTrax
    VersaTrax [OP] Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    Has anyone replaced the long hard brake lines that run from the front of the truck just under the driver door to the rear on a 2011-2015 Tacoma? One of the lines is seized on the rear and I’m weighing my options. I’m letting it soak in penetrating oil overnight but just may replace both lines since the fittings are corroded. I know the gas tank would have to be dropped but I’m unsure if the drive shaft frame support would need to be removed as well if possible.
  2. Dec 28, 2021 at 2:00 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I've had good luck with this on stuck brake lines. Just don't get it too hot.
    VersaTrax[QUOTED][OP] likes this.
  3. Dec 28, 2021 at 2:01 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Have also heard some heat will help get those unstuck.
    VersaTrax[OP] likes this.
