Replacing head gasket what else should I do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by FatalFoxCry, Apr 6, 2018.
  1. Apr 6, 2018 at 7:07 PM
    FatalFoxCry
    FatalFoxCry [OP] Well-Known Member
    1997 Toyota Tacoma Sr5 4x4
    Just 31's on it. (Currently being built, lots to come)
    Hey TW, I've noticed that I've been having problems with my coolant. My truck has been burning it for a little bit now. I'm just wondering what else I should do while I have the thing partly ripped apart. My plans so far, head gasket, valve cover gaskets, tune up on it. Any other things I should do while Im down there?
  2. Apr 6, 2018 at 7:09 PM
    FatalFoxCry
    I should have mentioned the truck has almost 371,000 km on her
  3. Apr 6, 2018 at 8:47 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I would have the block and head resurfaced or at least checked for warping.
  4. Apr 6, 2018 at 9:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You have the v6? You mentioned head gasket singular and valve covers plural. OCD sent into panic mode!
    Running Board Man likes this.
  5. Apr 6, 2018 at 9:42 PM
    Glamisman
    Glamisman Well-Known Member
    if it were me I would have the head(s) checked for cracks.
    You can clean the block up pretty good with new 6 inch wet stone and some WD 40. A couple of light passes to clean the old gasket material then flip the stone over to the fine side and make a couple more light passes. You are surfacing it, not filing it. Then put a clean straight edge on it to check for any warpage. Might as well adjust the valves while it is off too.
    Dalandser likes this.
  6. Apr 6, 2018 at 10:22 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    A lot of what is being suggested can be found in this video series. 3 hours long so grab some popcorn if you want to get through the whole thing:
  7. Apr 7, 2018 at 12:29 AM
    FatalFoxCry
    Sorry it's a 3.4
  8. Apr 7, 2018 at 12:31 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Not sure what your experience level is, but you'll have to make the decision whether you want to do both headgaskets or find out which one is leaking (if one is leaking) if you only want to do that one.
  9. Apr 7, 2018 at 2:51 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Subbed as I’ll be doing this soon. :thumbsup:
  10. Apr 8, 2018 at 7:55 PM
    FatalFoxCry
    I'd be doing both if I'm doing one. I'm not the most experienced but I'm getting better. I've redid a bit of the truck already so I'm up for a challenge.
  11. Apr 8, 2018 at 7:57 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Have you checked out that video? Not to tell you what to do, but as an alternative to doing both hg's you could pop in a new motor. JDM long blocks w/ less miles than yours go for $1k or less and it's possible to come up on a good running motor out of a wreck once in awhile - I got a low miles engine and trans for $1450 out of a running truck. It wouldn't be any more work in terms of hours involved, just a little more heavy lifting with removing the trans and engine.
    Marcmtb1 likes this.
  12. Apr 8, 2018 at 8:05 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Timing belt, water pump (toyota OEM parts) and any pulley bearings that are iffy.
    BassAckwards likes this.
  13. Apr 9, 2018 at 3:05 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Definitely knock sensor pigtails.
  14. Apr 9, 2018 at 3:43 PM
    BarnBoy
    BarnBoy Well-Known Member
    96 Tacoma 2wd
    Valve clearances. Spark plugs. Anything thats easier to get at with the head off.
    BTW, GO TOYOTA OEM GASKETS ALL THE WAY! Worth the extra money. I did the head on my 2rz-fe, remanned head, checked all valve clearances, knock sensor wires, intake gaskets, exh. man gasket, EGR gaskets, etc. I got a valve grind gasket kit from Toyota. Only thing it doesent have are new injector cup spacers which you probably dont need.
