Replacing Ignition Cylinder on 2003 DCSB
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoTruck808, Oct 23, 2017.
  1. Oct 23, 2017 at 5:07 PM
    TacoTruck808
    TacoTruck808 [OP] Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Hi, A friend of mine just purchased a used 2003 Tacoma DCSB. He wants to change the ignition cylinder with a new one and I am going to help him do this. I am looking to see if anyone has done this to their 1st gen Taco or if someone has some instructions on how to do this. Even a page from the factory service manual would help. Thanks!
  2. Oct 24, 2017 at 12:49 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The ign switch assembly is held on by 2 screws that the heads twist off. So they have to be drilled out. If you need to replace the complete assembly. If your replacing just the tumbler see the attached file.
    TacoTruck808[OP] and Dalandser like this.
  3. Oct 24, 2017 at 8:52 AM
    TacoTruck808
    Thanks @mechanicjon! I am only replacing the tumbler so the PDF is exactly what i needed.
  4. Oct 24, 2017 at 9:50 AM
    Glamisman
    Glamisman Well-Known Member
    if it was me I would get the new cylinder rekeyed to the original key... multiple keys and multiple sets of keys is a real pain in the rear. The other thing I would do is not twitst the security bolts to the point where the heads twist off... it makes taking the lock bolt cylinder easier to take off next time.
  5. Oct 24, 2017 at 9:56 AM
    TacoTruck808
    actually, I would rather re-key the door lock cylinders to match the new ignition cylinder. Has anyone done that? Is that difficult to do?
  6. Oct 24, 2017 at 10:04 AM
    Glamisman
    need to go to a locksmith ... toyota uses what is called a split wafer for anti theft purposes and there are so many different wafers needed that it isnt economical for us at our level of repair to do.
  7. Oct 24, 2017 at 10:10 AM
    TacoTruck808
    ok. Thanks for the info. My friend will use his keyfob most of the time so he wasnt too concerned that the door keys didnt match the ignition, just wanted new keys.
  8. Oct 24, 2017 at 12:37 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If that is the case why not just rebuild all the lock cylinders instead of buying new .
  9. Oct 24, 2017 at 7:30 PM
    TacoTruck808
    I guess he could have done that but he wanted an easy solution so he decided to just replace all the cylinders. At least the doors match.
