Replacing injectors, what else while I’m there?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BeLance89, Nov 30, 2017.
  1. Jan 27, 2020 at 6:32 PM
    #41
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Yup, the original FPR on my 314+k mile 3.4 failed after sitting dry for almost a month waiting for my rebuilt injectors to come back. Causes a fuel leak into the air box. In my case, it destroyed the rubber gasket that seals the air filter as well and I had to replace both the FPR and the airbox.
  2. Jan 27, 2020 at 6:36 PM
    #42
    Dufus
    Dufus Well-Known Member
    Located in Colorado
    99 Taco 3.4L manual 4x4 SR5 - Imperial Jade Mica
    Mods: bent frame and sun weathered roof paint.
    Thank you for the info again. Really appreciate it and I'm sure others in the future will too. I'd be a fool to ignore the advice I think.
  3. Jan 27, 2020 at 7:10 PM
    #43
    Dufus
    Located in Colorado
    I'm having a hard time finding replacement fuel injector rail crush washers (gaskets). I normally go through rock auto but I don't see them available on their site and the manual I have doesn't give specific info on them.
  4. Jan 27, 2020 at 7:14 PM
    #44
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  5. Jan 27, 2020 at 7:16 PM
    #45
    Dufus
    Located in Colorado
    xtremewlr[QUOTED] likes this.
  6. Jan 27, 2020 at 7:44 PM
    #46
    Dufus
    Located in Colorado
    What website did you find this deal on the FPR?
    CS_AR[QUOTED] likes this.
  7. Jan 27, 2020 at 8:12 PM
    #47
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Dufus[QUOTED] likes this.
  8. Jan 27, 2020 at 8:22 PM
    #48
    Dufus
    Located in Colorado
    Thanks again. As a novice, this is my first time delving in this deep. Wish me luck.
    MainerDave19995VZ and CS_AR like this.
  9. Jan 28, 2020 at 3:28 AM
    #49
    CS_AR
    Good Luck. Be sure to lubricate the o-rings before installation. I've see a number of improperly lubricated o-rings become pinched and leak after installation.
    I use a crows foot wrench, like in the video, to torque up the banjo bolts.
  10. Jan 28, 2020 at 11:16 AM
    #50
    Dufus
    Located in Colorado
    Will do, I am planning to lubricate them with gasoline. Also thank you for the referral on the OEM FPR part. It was a great deal!
  11. Jan 28, 2020 at 2:02 PM
    #51
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Use a thin coat of Super Lube multi-purpose high temperature grease - it's cheap and can be bought at Harbor Freight. They also make a specific o-ring lube, but it's not necessary for this application. I don't think gasoline is a very good lubricant, but its better than putting them in dry.
    Dufus[QUOTED] and CS_AR like this.
  12. Jan 28, 2020 at 2:27 PM
    #52
    CS_AR
    I've been using Super Lube for injector o-ring installations for over 10 years now. Always good results. I think I learned about it from Deatschwerks.
  13. Jan 29, 2020 at 3:51 PM
    #53
    Dufus
    Located in Colorado
    Thank you. I'll grab some.
    MainerDave19995VZ likes this.
  14. Jan 30, 2020 at 12:14 PM
    #54
    MainerDave19995VZ
    MainerDave19995VZ Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    I’m doing this Monday in my driveway but only the 1,3,5 cylinders. I’m doing the other side when it warms up. The crush washers for the banjo bolts were the toughest part to get. I’m going measure one and order a bag of them to have on hand for the future. Good luck on your project! Keep us posted.
    The thread I started a couple days ago: https://www.tacomaworld.com/threads...sfire-and-rough-running.649758/#post-22580975
    Dufus likes this.
  15. Jan 30, 2020 at 3:24 PM
    #55
    Dufus
    Located in Colorado
    Good luck to you as well. I've been graced with a garage just deep enough to work on the truck engine, it's tight but works. Be careful when ordering those specific washers. I believe they are made of a non-magnetic, softer metal so they can crush a bit.
  16. Feb 1, 2020 at 4:16 PM
    #56
    MainerDave19995VZ
    David
    Maine
  17. Feb 1, 2020 at 6:42 PM
    #57
    Dufus
    Located in Colorado
    I replaced the injectors and got her all put back together. Also replaced the fuel filter and FPR as planned. I also ended up replacing 3 or 4 air/vac hoses. After starting her once, she's running rough... Is this normal the first few starts? Also had a few misfires (p0303 , p0304) on two different injectors on the first start. I haven't started her up a second time yet. No leaks or anything and everything looks tip-top. Will she calibrate herself out after a few starts? I haven't found much as to things to look out for post replacement. Anyone have any tips or advice as to what to look out for?
    CS_AR likes this.
  18. Feb 1, 2020 at 6:57 PM
    #58
    CS_AR
    I don't remember any misfires. It might have been rough for the first few seconds. Though I did a complete engine swap. Check for vacuum leaks around the throttle body and intake manifold. I guess it won't hurt to let it idle while you check for vacuum leaks.
  19. Feb 1, 2020 at 7:05 PM
    #59
    Kiloyard
    Phoenix, AZ
    I don't think this is normal. After priming the fuel line mine fired right up and ran smooth. Did you disconnect the battery and allow the ECU to reset?
  20. Feb 1, 2020 at 7:09 PM
    #60
    Dufus
    Located in Colorado
    Battery was disconnected during the whole replacement. No vac leaks on the second start up (just let it idle). Started right up and seemed ok. Hard to tell without driving it. No apparent vacuum leaks.
