Replacing instrument cluster light on a 99
Discussion in '1st Gen. Tacomas (1995-2004)' started by evergreentacoma, Oct 2, 2009.
  1. Oct 2, 2009 at 11:32 AM
    evergreentacoma
    evergreentacoma [OP] New Member
    Tacoma TRD
    The instrument cluster light over the tachometer/temp guage has burned out in my 1999 Tacoma TRD. I am looking for direction on how to replace the light.
    I am guessing there is no way to replace the light without removing the instrument cluster. I am also thinking that the 1999 has bulbs and not leds.
    Any thoughts/wisdom on this replacement would be appreciated.
    Respectfully,
    Evergreentacoma
  2. Oct 2, 2009 at 2:04 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
  3. Jun 30, 2014 at 11:27 AM
    multiminpins
    multiminpins Member
    Bob
    Charlotte, NC
    '99 Tacoma SR5 4x4
    Bluetooth.
    The link doesn't work.
  4. Jun 30, 2014 at 1:17 PM
    CleanSC
    CleanSC ASE Certified Master
    Jose
    Miami
    '02 Reg Cab PreRunner 2.7
    You need to remove the cluster to do this.
    To do that, you need to remove the radio/a/c bezel (not all the way), the ignition ring/clock panel, the lower knee panel (10mm bolts), and the cluster bezel (two top screws to dash shroud). Cluster bezel has a little hidden screw on the lower left, careful with that one. Unplug your hazard light switch, rheostat, and ECT/clutch cancel button.
    Finally, steering column cover. Screw on bottom, two screws behind steering wheel. (Turn it to see them facing you from driver seat.)
    After all this, there's four screws on the cluster. Pull out some, and pop off the three harness connectors. After that you're free.
    That should be everything. Also there's DIY's of this with pics all over.
    And no, they are not leds. You can put some in tho. Tachless gauges take only 2 #194 bulbs. Tach gauges take 4.
    Good luck!
  5. Jul 1, 2014 at 9:26 AM
    multiminpins
    multiminpins Member
    Bob
    Charlotte, NC
    '99 Tacoma SR5 4x4
    Bluetooth.
    Thanks! I think I'll wait for cooler weather to start this task.
