Replacing Instrument Panel Lights in 02 Tacoma
Discussion in 'Technical Chat' started by BenHyman, Jan 18, 2009.
  1. Jan 18, 2009 at 7:17 PM
    BenHyman
    BenHyman [OP] New Member
    Minneapolis
    2002 Toyota Tacoma Ext Cab
    Hello; I'm new to this forum. I drive a 2002 Tacoma Ext Cab. I noticed that two of my instrument panel lights (the ones behind the Tachometer and Engine Temp) have gone out. Could this be a lightbulb problem or a fuse problem? Do I need to replace the bulbs or look at the fuses? If it's the fuses, which one might be the culprit. Any help would be appreciated.
    Regards
    Ben Hyman
  2. Jan 19, 2009 at 11:50 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    It's the bulbs. All your dash illumination would have disappeared if the relevant fuse had blown ...
  3. Jun 13, 2013 at 9:14 AM
    chris fugere
    chris fugere Member
    I WANT TO REPLACE MY DASH LIGHTS IN MY 08 TACOMA TO LED BLUE. ONCE I PULLED EVERYTHING OUT THERE A 3-4 BIG BLK KNOBS AND WONT TURN WHAT ARE THESE
  4. Jun 17, 2013 at 9:10 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    No need to yell there Chris. lol.
    The black "knobs" to which you are referring to are the actual bulb sockets. Sometimes they do tend to be a bit sticky, but you should be able to twist them loose with one hand.
    Word of warning: BEFORE you install your dash and cluster with your new LED bulbs installed, connect the electrical connection and turn on your park lights to be sure they all light up. LEDs are polarity specific, so you can sometimes install them backwards and they will not light. If any bulbs do not light up, simply pull the black socket out and turn it 180 deg and reinstall.
  5. Jun 19, 2013 at 5:30 AM
    chris fugere
    chris fugere Member
    I dont think they r the light sockets I think theyre for rpm, speedometer needles
  6. Jun 20, 2013 at 7:11 PM
    BamaToy1997
    Bill
    Navarre, FL
    All of that is hardwired in Chris. Perhaps you could take a picture and show exactly what you are meaning?
