Replacing JBL Factory amp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Braxtoncaudle, Jun 3, 2022.
  1. Jun 6, 2022 at 3:07 PM
    Braxtoncaudle
    Braxtoncaudle [OP] Active Member
    2021 Grey Tacoma TRD SPORT
    Ok perfect, thank you! Did you replace any of your JBL speakers besides the sub?
  2. Jun 6, 2022 at 4:24 PM
    iLLFadedBowl
    iLLFadedBowl Well-Known Member
    2019 Super White TRD Offroad Tacoma
    Remote start w/ vehicle control and locator, Prinsu rack w/ Cali Raised Light Bar and 360 LED lights, LED Bedlights, Tailgate lock, 3" Lift, Wheels and Tires, Raptor Lights, LED headlights and fog lights, Blacked out LED taillights, Front windshield eyebrow tint, Rough country bed molle, 8-gang switch to control LEDS, Dominator D6 running boards/side steps, Blacked out sequential mirror turn signals
    I replaced all the door speakers and tweeter. The only thing I'm using from the factory is the head unit.
  3. Jun 6, 2022 at 4:26 PM
    Braxtoncaudle
    Do you think I have to? And if so what did you use or recommend
  4. Jun 6, 2022 at 4:47 PM
    jdrummer
    jdrummer Well-Known Member
    Arizona
    21 TRD OR
    I got my truck a year ago and I posted about the bass sounding week driving home after work specifically in the summer time... no one else seemed to have this problem. Guess I'm not the only one.
    dms91 likes this.
  5. Jun 6, 2022 at 4:52 PM
    Braxtoncaudle
    yes! Especially when it’s hot out it’s the worst
  6. Jun 6, 2022 at 6:02 PM
    metalmule
    metalmule Well-Known Member
    21 DCSB
    that kenwood, maestro combo is great. I've got it powering the entire vehicle including the sub, aftermarket crossover makes the doors/front corner speakers into two channels instead of 4.
    You can fit the kenwood amp under your passenger seat if you purchase a seatjacker system for that side.
  7. Jun 6, 2022 at 6:06 PM
    metalmule
    21 DCSB
    btw I'm using the factory sub enclosure and get great sound. had to dynamat the entire thing and I changed the woofer out though for a kicker. aftermarket sub may be worth it but it isn't necessary.
    Braxtoncaudle[OP] likes this.
  8. Jun 6, 2022 at 6:08 PM
    iLLFadedBowl
    Do you know how many watts your pushing to the sub? Interesting that you are using the oem enclosure.
  9. Jun 6, 2022 at 6:08 PM
    Braxtoncaudle
    So does the kicker sub fit in its enclosure? Do you have a picture of it?
  10. Jun 6, 2022 at 6:11 PM
    Braxtoncaudle
    what kind of speakers did you get? Was it plug and play
  11. Jun 6, 2022 at 8:29 PM
    iLLFadedBowl
    I got some aftermarket JBLs. They werent plug and play. If you order from crutchfield though they have plug adapters and brackets if you need them.
  12. Jun 6, 2022 at 8:32 PM
    Braxtoncaudle
    Ok how much watts are they? Did it make that big of a difference to where you think I should do it
  13. Jun 6, 2022 at 8:49 PM
    iLLFadedBowl
    Not sure on the wattage. They do make a difference especially the tweeters in the dash. In my opinion yes you should replace them especially since you are replacing the amp. It seems you have caught the audio bug. Next you will be asking about sound deadening. Which I think is the most important and you see the biggest change. :spending:
  14. Jun 6, 2022 at 8:53 PM
    Braxtoncaudle
    Haha yes I can’t do anything without music so I knew when I got it it needs to be done. Are the tweeters JBL too?
  15. Jun 6, 2022 at 9:40 PM
    #35
    iLLFadedBowl
  16. Jun 7, 2022 at 9:57 AM
    #36
    Braxtoncaudle
    Perfect thank you! I might try his method and use the same JBL sub enclosure with the kenwood and AR. I will also replace all JBL with after market JBL speakers as well.
  17. Jun 7, 2022 at 11:42 AM
    #37
    metalmule
    21 DCSB
    Sorry its a RF sub.
    Rockford Fosgate P3SD2-8 8" Dual 2-Ohm Punch Series Shallow Mount Car Subwoofer
    Its perfect.
    Using the Kenwood system so I think 100 watts RMS to each channel on a 2 channel subwoofer.
  18. Jun 7, 2022 at 11:55 AM
    #38
    Braxtoncaudle
    Oh ok perfect, I’m probably going to get the JBL aftermarket speakers as well and if I can use the OEM enclosure that’s even better.
  19. Jun 7, 2022 at 11:56 AM
    #39
    Braxtoncaudle
    Was the RF sub a big difference?
  20. Jun 7, 2022 at 12:25 PM
    #40
    metalmule
    21 DCSB
    Once the amp was in the sub did make a difference. Adjusting the settings on the DSP and making sure I had my polarity correct made an even bigger difference. I think that swapping out the front door woofers and the subwoofer will give you a suitable bass response for most music. An aftermarket sub enclosure for the back can get you a suitable bass response for almost all music and if that isn't enough then you can add in an epicenter.
    If you really want the sound to shine then go ahead and soundproof the doors, the outer skin and the inner portion. Soundproof the back wall behind the rear seats if you're really bored.
    Best bang for your buck comes from changing out those front speakers, the issue with going the route of a component system is that there's nowhere to put the additional tweeters.
