Replacing JBL Head Unit with Non-JBL One
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dpcarlton, Mar 20, 2022.
  1. Mar 20, 2022 at 6:22 PM
    Dpcarlton
    Dpcarlton [OP] Member
    2019 DCSB TRDOR
    I am looking to replace my 2019 OEM Head Unit with a (potentially) OEM non-JBL one from a 2021. End goal is to get CarPlay.
    Is this plug and play or are there any gotchas with going from JBL to non-JBL?
    I can only see threads with folks going the opposite way.
    Any info would be appreciated!
  2. Mar 20, 2022 at 7:18 PM
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
  3. Mar 20, 2022 at 7:23 PM
    Dpcarlton
    2019 DCSB TRDOR
  4. Mar 21, 2022 at 4:34 AM
    bhbuster
    bhbuster Active Member
    Visit Crutchfield. This site will tell you everything you need to do. I changed out my JBL head unit for a Kenwood while retaining all the JBL speakers and factory controls & settings. Crutchfield site will walk you through what is needed. Just keep in mind the cost may add up to $250 in adapters and modules over the cost of the head unit...
  5. Mar 21, 2022 at 5:34 AM
    Dpcarlton
    2019 DCSB TRDOR
    Thanks, but that does not really help me. I am looking to go from an OEM JBL to an OEM non-JBL. I am not looking at an aftermarket head unit.
  6. Mar 21, 2022 at 5:45 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I thought the JBL was the best so why go to non JBL. I would not know the difference as my 2021 has a non JBL.just saying
  7. Mar 21, 2022 at 5:50 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    It will not just be a head unit swap. The jbl systems completely different wiring setup than non jbl radios.
    musicisevil, Chew and na8rboy like this.
  8. Mar 21, 2022 at 5:54 AM
    Dpcarlton
    2019 DCSB TRDOR
    Thanks, besides a wiring harness, would anything else be needed like an AMP, etc?
  9. Mar 21, 2022 at 6:52 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Well your jbl system currently is setup where the headunit sends everything to the jbl amp, from there the jbl amp is wired straight to the door speakers. So if you can wire the non jbl headunit to send the correct signal to the jbl amp you should be fine. You are probably better off sourcing a jbl headunit if I am being honest
  10. Mar 21, 2022 at 6:56 AM
    Dpcarlton
    2019 DCSB TRDOR
    Thanks. Honestly have not seen any for sale. The non-JBL one I ran across, but will keep looking.
  11. Dec 4, 2023 at 12:44 PM
    Charles_Dickens
    Charles_Dickens Member
    2017 Black OR DCLB
    Did you ever figure out the answer to this question? I'm trying to do the same thing, essentially downgrade from JBL system in my 2017 and get a non JBL stock headunit from a 2020+ since they're way more abundant on sites like eBay and a helluva lot cheaper too.
  12. Dec 4, 2023 at 4:50 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    can you install the radio? yes
    will it output audio? no
    you'd need to install the oem-side non-jbl speaker wiring harness, and then run speaker wiring to every speaker location, as well as install the non-jbl speakers for the entire thing to work.
  13. Dec 5, 2023 at 5:33 AM
    Charles_Dickens
    2017 Black OR DCLB
    Appreciate the input. So in the end, it doesn't sound very worth it for all the work that needs to go into getting it working properly.
