Replacing JBL speakers 12' trd sport DCSB
Discussion in 'Audio & Video' started by Paco3010, Jan 8, 2013.
  1. Jan 8, 2013 at 3:52 PM
    Paco3010
    Paco3010 [OP] Member
    Craig
    Hanover PA
    12' TRD Sport DCSB 4x4 stock (for now)
    Just ordered a new HU to replace the stock JBL unit...my question is, how hard is it to replace the "stock" JBL speakers? Not including the amp....from what I've seen so far this system is a pain to deal with so just checking before I get my hopes up...im talking about being able to use the existing cable wiresinstead of running all new wires? thanks!
  2. Jan 17, 2013 at 12:55 PM
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    Lexington, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    i dont exactly understand what your asking... are you wanting to know if you can replace the speakers and use the jbl amp? if thats what your wanting to do i doubt it will sound good because most of the jbl speakers either work at 8ohms and it would either burn up the amp because aftermarket speakers run at 4ohm or it would just sound bad.. or are you wanting to know if the wires for the factory speakers can be found behind the radio so you can wire them in with the new radio?
  3. Jan 17, 2013 at 3:28 PM
    Paco3010
    Craig
    Hanover PA
    Thanks Kevin, yes that's basically what I'm asking...if I can simply replace the stock speakers and continue to use the amp? At this point I have found the JBL system is a pain if you wanna upgrade.....
  4. Jan 17, 2013 at 3:30 PM
    Aw9d
    Aw9d That one guy
    Yes you can replace the speakers and run them off the JBL amp. The must match ohm ratings and power ratings or you'll burn up the amp.
    Honestly, ditch the JBL amp for the doors as the speaker selection you get that you can use with that amp isn't worth the money you'll spend. I'd just stick with the JBL combo if you don't want to swap the amp out. You still can use the JBL for the sub if you want. Buy a proper amp with good speakers and you'll be much happier in the long run.
  5. Jan 18, 2013 at 5:30 AM
    Paco3010
    Craig
    Hanover PA
    Thanks bro...thats the kind of info i was looking for!
