Replacing JBL system...wire harness issues.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dallas24, May 14, 2012.
  1. May 14, 2012 at 9:54 AM
    dallas24
    dallas24 [OP] Member
    Dallas
    Chandler
    08 4x4 DC/LB Sport
    Borla Cat-back exhaust, K&N CAI, Airaid TBS, 17" KMC XD Revolvers, 6" Pro Comp suspension lift, Xenon headlights and foglights, King Coilovers with TC UCAs, shackle flip with Alcans and 14" King Bypass shocks, grillecraft grille, Stubbs Rubicon rock sliders, complete aftermarket stereo system with two 12" subs, smoked taillights, 30" Rigid light bar, Rigid D2 fogs, Rigid Dually reverse lights.
    I am replacing every component of my JBL system including the amp/sub/speakers. The issue I am having is trying to find a wire harness that will work with the wire harness that needs to plug into the aftermarket head unit for illumination and power and what not. The typical wire harness that you can buy at walmart or best buy is only designed for the non-jbl stereo harness, but the JBL upgrade has a different wire harness that i cannot find anywhere or find info on. They make a harness that is designed to work with the JBL system, but it's designed to keep the JBL amp/sub/speakers. But I'm not keeping any of it, it's all being replaced by aftermarket components. Has anyone had success replacing their entire JBL system and found a solution to the wire harness issue?
  2. May 14, 2012 at 9:59 AM
    medic2230
    Murph
    Bama! Roll Tide
  3. May 14, 2012 at 10:04 AM
    medic2230
    Murph
    Bama! Roll Tide
    Well if your going to all that trouble rewire the whole thing. :D
    Maybe try the FSM and see if they have a schematic of the JBL plug in there.
  4. May 14, 2012 at 10:34 AM
    dallas24
    Dallas
    Chandler
    08 4x4 DC/LB Sport
    The non-JBL wire harness does not work with the JBL harness. The connections are different.
  5. May 14, 2012 at 10:37 AM
    dallas24
    Dallas
    Chandler
    08 4x4 DC/LB Sport
    Do you think I could splice into the these wires somehow and connect my aftermarket HU that way?
  6. May 14, 2012 at 12:16 PM
    YoungGunz23
    YoungGunz23 Well-Known Member
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    3" fabtech lift 33" federals
    go to sonicelectronix.com and look wiring harneses for a tocoma with your year model and it will ask you if you have a JBL system and they have the wiring harness for it.
    look at this link this is the wiring harness that you need.
    -http://www.sonicelectronix.com/viewcat.php?category_id=95&f_701_2635=1&f_894_3428=1&f_896_3435=1
    good luck on your system, remember to post picks!:cool:
  7. May 14, 2012 at 12:18 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    just from person experience dont splice your wires on the wiring harness. reason being if it actually works you will be lucky, and if you ever (for some God awful reason:confused:) decide to sell your taco you wont be able to sell your stock HU with it because it will be impossible to hook up.
  8. May 14, 2012 at 8:58 PM
    dallas24
    Dallas
    Chandler
    08 4x4 DC/LB Sport
    Thanks for the responses, I'll be sure to post some pics after I'm done. This issue has been holding me up for a couple weeks now. Everything else is done so I've been itching to get the sound going. The end is near though!!!
  9. May 14, 2012 at 9:02 PM
    Aw9d
    Aw9d That one guy
    I just went through this myself and it boiled down to tapping into the factory wiring harness and not using any harness adapters. I got everything I needed, just get a volt meter out and it won't take very long to figure out.
  10. May 15, 2012 at 12:27 AM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    can you get the jbl harness and then cut into that to connect to the new HU so you can revert to factory by removing the jbl if need be? i have no idea what the jbl harness looks like, just putting this out there...
  11. Sep 18, 2012 at 7:50 AM
    08navytrd
    08navytrd Well-Known Member
    Kenneth
    Italy
    08 Prerunner TRD Sport
    K&N CAI Flowmaster super 40 dual exhaust, Upgraded 6 disc from factory single disc, mag light attached to driver door, bilstein 5100 set at highest up front and 5100s in the rear, 1.5'' add a leaf in rear, aftermarket black headlights, 35w hids 6000k low beams, 4 85w HID off road lights 6000k color,
    i know this is old but did you ever pull your whole system out? JBl and all
  12. Sep 18, 2012 at 7:08 PM
    shorty90892
    shorty90892 New Member
    Corey
    yorba linda
    09 PreRunner sport
    lift, grill rims, tires, stereo system.
    I have put in 2 10' subs and rewired my door speakers to my pioneer head unit but for some reason my 2 front speakers don't work and the music just plays through the 2 front tweeters.... anyone else have this problem??
  13. Oct 19, 2012 at 8:54 AM
    jono55
    jono55 New Member
    '11 Taco 4x4 TRD Sport
    Toyota Tacoma OEM "Rugged Trails" Black Wheels, and some other OEM stuff.
    If you want to sell the entire JBL system that you pulled, let me know! I'm looking for one!
  14. Oct 23, 2012 at 4:03 PM
    shorty90892
    Corey
    yorba linda
    09 PreRunner sport
    What are you looking to buy off of the old system?
  15. Oct 23, 2012 at 4:53 PM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
  16. Oct 24, 2012 at 11:11 PM
    shorty90892
    Corey
    yorba linda
    09 PreRunner sport
    I have an amp just like that minos the wires though I can also sell the subwoofer with it
