Replacing Key Fob
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cullenk456, Aug 12, 2021.
  1. Aug 12, 2021 at 3:52 PM
    cullenk456
    cullenk456 [OP] Member
    Oregon
    Sorry if this has been addressed in a previous thread.
    My Dad has a 2018 Sport. He received 2 key fobs from the dealership at the time of purchase. About a year ago he lost one of the fobs. He's been getting by with the one, but would like to have a spare. The Toyota dealership wants $400 to replace it, ace hardware would do it for $200. He went to ace but was told that they couldn't program a new fob because records show that there is already two keys for the truck. Anyone run into this issue before? Any solutions.
    Thanks
  2. Aug 12, 2021 at 4:16 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    You might try a proper locksmith. It can have up to 7 smart fobs. The fast way is to simply add a new one as the third. The correct way is to remove the lost key from the system and add the new one as the second.
  3. Aug 12, 2021 at 4:19 PM
    mhornco
    mhornco Well-Known Member
    Bought an unlocked FOB for 54 bucks. It was a knockoff. Downloaded tech stream from a link here and 2 minutes later I now have another FOB. It was extremely easy. BTW this was the fob for a push button start
    Tacospike likes this.
  4. Aug 12, 2021 at 4:22 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    Yup^^
    If you and your dad both have Tacomas, you should look into getting a Tactrix cable and Techstream. You can program your own keys, perform some minor customizations on your truck,perform ECU TSBs, and use it to troubleshoot error codes when your trucks both get a little older and start needing maintenance.
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
