Replacing Knock sensors and harness in 3400
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greasepatchworker, May 24, 2016.
  1. May 24, 2016 at 3:56 PM
    Greasepatchworker
    Greasepatchworker [OP] New Member
    Shane
    1996 Toyota Tacoma
    who has tackled this and how tough to get at was it? I've been told there are two differant brands of sensors one brand I can get at Napa the other only Toyota.
  2. May 24, 2016 at 4:07 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Go with oem stuff. Their located under the intake plenum in the valley of engine. Pretty straight forward but it takes a while to get everything unbolted and out the way. Youl probably want to change all the intake gaskets too.
    If your only throwing a code for one bank a temporary solution is to splice the signal wires of the 2 together. This will atleast get your truck out of limp mode.
  3. May 24, 2016 at 5:06 PM
    dapavinator
    dapavinator Member
    Alberta, Canada
    1996 Tacoma 3.4L and 2013 Honda CR-V
    Came with: 20" LED Light bar, SportRack Roof Rack, Remote Starter
  4. May 25, 2016 at 9:56 AM
    Greasepatchworker
    Shane
    1996 Toyota Tacoma
    Thanks for the info guys does anyone know of a youtube video on this?
  5. May 25, 2016 at 12:15 PM
    devinzz1
    devin
    2023 aclb trd or mt
  6. Jun 1, 2016 at 6:46 PM
    ashleyroachclip
    ashleyroachclip Well-Known Member
    I bought the harness , genuine toyota ,and 2 knock sensors , also genuine toyota , from Amazon.
    Harness was 34.00 , sensors were 98.00 each.
    I did not replace the gaskets, I had recently replaced the entire top end, and the gaskets are mls , and can be reused if you don't damage the lowered gasket that has rubber inserts at the water jackets.
