Replacing my TC UCAs with the SPC UCAS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrgoodwrench, Sep 10, 2011.
  1. Sep 10, 2011 at 10:29 AM
    mrgoodwrench
    mrgoodwrench [OP] New Member
    Olympic Peninsula
    08 DCLB lifted
    total chaos upper control arms, Icon Vehicle Dynamics coilovers, protech box and cabgaurd, outfitted for a logging crummy
    I just got my SPC UCAs in the mail yesterday. I'm going to be replacing my TC ones tomorrow. I'll get some pics of the TC parts to show the damage from hard daily driving on rough logging roads. This truck is not abused, but takes a constant beating from rough haul roads as I drive it for my job. I'm tired of rebuilding the stupid uniball arms. The TC arms are avaialble for anyone who might want to purchase them. I do not think you should run them in a wet and dirty environment like the PNW as I have. Sealed, and greased joints are the only way to go here.
    My last rebuild on the TC arms was a measly 12,000 miles ago, and they have been making noise for the past 6,000. So uniballs leading a wet and dirty life are good for about 5-6000 miles before they are solid metal on metal with about 1/8 inch of slop.
    Pictures coming tomorrow.....
  2. Sep 10, 2011 at 10:52 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Stainless uniballs, like what camburg uses, would be better. You can replace the TC chrome uniballs with stainless
  3. Sep 10, 2011 at 11:07 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    My SPC LR arms just failed after 9 months of use. Balljoint and a bushing on one arm, which makes me question the other arm as well... working with SPC and Wheelers on a fix, sounds like they want me to buy a new arm and ship them my old one so they can decide if they will warrantee it
  4. Mar 2, 2012 at 5:21 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  5. Mar 2, 2012 at 5:22 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    yep... so how much you selling those TC UCA's for :D
  6. Mar 2, 2012 at 5:27 AM
    XXXX
    sKiP
    05 Prius
    Just deduct $120 for new balls then depreciation for being used and your good to go.
    Get him to take a picture of the bushings cause they are $$$$ before buying them. Mine have little to no wear after 30k, but who knows if his were installed and maintained like mine were.
    :D
    Wish I got mine used.
  7. Mar 2, 2012 at 9:14 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Well I should update my last post by saying Wheelers and SPC took care of me. I didn't pay a dime, just my time to install two new redesigned arms.
  8. Aug 1, 2012 at 1:14 PM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    What was redesigned?
  9. Aug 1, 2012 at 1:21 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I thought just the bushings were redesigned
  10. Aug 1, 2012 at 2:17 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I just had the exact same thing happen with my SPC UCA's. Both balljoints went bad as well as a bushing on the drivers. Talk to SPC and within a day they had shipped brand new arms with their newly designed balljoints and bushings. What a great company to deal with. Did I mention my UCA's ha 50k kms on them and were two years old! :-o
    Edit. Also just found a torn boot on the DS LCA. May as well get everything fixed at the same time.
  11. Aug 1, 2012 at 2:25 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    FK Uniballs for $40:
    http://www.ebay.com/itm/FK-Bearings...DefaultDomain_100&hash=item35be8da9a8&vxp=mtr
  12. Aug 1, 2012 at 6:07 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    They redesigned their bushings and the ball joint boots. They fit a lot tighter, on the old ones they were loose around the top and could fall off, they also had a gap around the bottom. These new ones they're held on the top really well and the bottom is tight around the ball joint stud. Much better design, less crap to get into your ball joint.
    I might add I found a cool lube product for you guys with uniballs. Try some dry moly spray lube on those, I bet if you keep up on it you would extend the life of em by a fair bit.
  13. Aug 1, 2012 at 6:11 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How much for the tc
  14. Aug 2, 2012 at 7:56 AM
    XXXX
    sKiP
    05 Prius
    My FK balls are still good :cool:
    My lower shock heims are now shot though :(
