Replacing O2 and Air/fuel sensor but have part number ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, Dec 18, 2016.
  1. Dec 18, 2016 at 5:45 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    I am about to replace both my up and down stream sensors on my 2001 Ext. Cab 3.4L 4x4 manual trans and I think I have the right part numbers to order but I read something about California being different parts for their sensors. My upstream sensor part # is Denso 234-9003 and the downstream is Denso 234-4189. Is this all correct for the manual trans and it being a CA truck? Thanks! Before I got scolded, I have been reading threads on this for over half an hour and can't seem to get a clear answer. Thanks in advance!
  2. Dec 18, 2016 at 11:04 PM
    Bamahoyt
    Ted
    Knoxville, TN
  3. Dec 19, 2016 at 12:09 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    There were Tacomas originally destined for California from their factories. California had more stringent emissions regulations than the rest of the country. Toyota made the exhaust extra efficient in removing pollutants in these Tacomas. This is what is referred to as a Cali truck. If the sensors you need are indeed for a Cali truck, the part description of the correct Denso sensor will specify that it's for a Cali emissions vehicle.
  4. Dec 19, 2016 at 12:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Then the thing is these California emission trucks are all over the country not just in California
    Just go to Denso Aftermarket look up the numbers for the specs of your vehicle .
    Seems the 2000 year was the last year for the two different emission packages in 2001 they are the same unless there is a glitch in Denso`s catalog
    The part numbers you have are the same ones I come up with using your info.
    I double checked on Denso and Napa Prolink you should be good to go.
    As these should both be plug and play
  5. Dec 19, 2016 at 7:20 AM
    Bamahoyt
    Ted
    Knoxville, TN
    You guys are the bomb! Thanks a ton!
  6. Dec 19, 2016 at 8:07 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
  7. Dec 19, 2016 at 8:52 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Hey guys, Speaking of O2 sensors, one of mine is triggering my engine light on. My mechanic told me one was bad, but have to take my truck back to his shop so he can check and see which one I need. He's very good with me on saving money, and lets me buy the parts online which is normally cheaper than his cost from local parts supplier. That being said, I know there are el cheapo aftermarket sensors out there. I prefer to get better quality or OEM. My question is, What brand or brands should I be looking for? Also, who online has the best prices on these? Amazon maybe? What should I expect to pay for one, ballpark?
    2003 Tacoma 3.4L 4x4 double cab.
    Sorry, not trying to hijack this thread.
  8. Dec 19, 2016 at 8:56 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Denso ONLY. Search the correct denso part number on Amazon and you can find the correct sensor much cheaper than in stores. Also, if you can find one in stock at a Advanced Auto parts, you can use a 40% off coupon and go pick it up (if you can find one in stock) Denso only, for the love of god don't use a Bosch or universal sensor.
  9. Dec 19, 2016 at 9:06 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Does manual or Auto trans make a difference in Emissions? Just wondering for when I have to replace these. I like to write down certain part #'s for future use. My truck was built in Fremont, CA went to NC for a little bit, made it's way back to CA and that's when I bought it. So it's a CA truck. Or should I just go off my VIN# for referencing Part #'s and not anything else?
  10. Dec 19, 2016 at 9:07 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    This is all you need. http://urdusa.com/store/Denso-Products-Oxygen-/-AFR-Sensors/c204_13/index.html?CDpath=6000
  11. Dec 19, 2016 at 10:02 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    Perfect, Thank You.....:)
  12. Dec 22, 2016 at 7:37 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    How do I get a 40% off coupon for Advanced Auto? I have a store here in my town? Never noticed their coupons, but then again, haven't looked for them. Any ideas???
    Thanks...:)
  13. Mar 21, 2024 at 3:02 PM
    danno4x4
    danno4x4 Member
    2004 Tacoma TRD
