Replacing O2 sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by pittim, Nov 24, 2008.
  1. Nov 24, 2008 at 3:22 PM
    pittim
    pittim [OP] mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    My truck is throwing code P0031, Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 1.) All I do is unbolt and unplug the old one and replace with the new one correct? Am I able to get at it from under the truck (03 V6 manual) easily or do I have more work ahead of me?
  2. Nov 24, 2008 at 3:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    should be easy enough to get to. you may wanna get some pb blaster and spray on the threads and let it sit for a little while..........those threads can get kinda rusty and be an ass to get off. you also may wanna get an o2 sensor socket.....they have a slot cut into them so you can get it over the o2 sensor easier............thats only if you dont have one already. other than that........unscrew,unplug, then install the new one.
  3. Nov 24, 2008 at 3:29 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    the PB blaster is an excellent idea, esp. if there's rust. but wipe it off before you put the new one in. if it gets in the new sensor it'll hose it.
  4. Nov 24, 2008 at 3:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah...i shoulda added to clean it off before installing the new one.:eek:
    Mcp58 likes this.
  5. Nov 24, 2008 at 3:56 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Thats the sensor from Denso that I'll be getting. Looks like I don't have to screw it in ya? So just spray down the bolts with PB Blaster, unscrew and unplug, wipe off the area that I sprayed down, then drop the new one in and just bolt and plug back in.
    Seems simple enough...
  6. Nov 24, 2008 at 4:04 PM
    HerNameIsLucy
    RIP Lucy.
    yup, 1st gens use two bolts to attach it. not sure about 2nd gens.
    my haynes suggests you run the engine a little before you break the bolts loose, get the pipe good and warm but not hot enough to burn yourself. guess it helps loosen things.
    also from experience you'll want to disconnect the battery for a few minutes after you replace it, or find a OBD scantool and erase the stored code in the ECU.
  7. Nov 24, 2008 at 4:05 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    Yes dont plug it in until you install it you dont want to twist the wires.
  8. Nov 24, 2008 at 4:24 PM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    i had a check engine light come on and my mechanic said it was the air fuel sensor and it was bank 1 sensor 1... are we talking about the same thing?
  9. Nov 24, 2008 at 4:31 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Yep, the O2 sensor is the thing that sends the ECU the "contents" of the exhaust so that the ECU can adjust the air/fuel ratio.
  10. Nov 24, 2008 at 4:37 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Ok, should I get Bosch or Denso?
    URD has the Denso for ~$185 shipped, and Advance Auto has the Bosch for $205. My parents want me to do it at home (I'm home till Sunday) so I'd have to get the thing shipped, so the Denso from URD would end up costing around $200.
  11. Nov 24, 2008 at 4:41 PM
    HerNameIsLucy
    RIP Lucy.
    OEM is Denso.
    Rockauto has them for $146. www.rockauto.com
    bought from them several times, even had to return something i screwed up ordering on...never a problem.
  12. Nov 24, 2008 at 4:48 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Oh wow, Rock Auto has the Denso with next day shipping for $160!
  13. Nov 24, 2008 at 4:50 PM
    HerNameIsLucy
    RIP Lucy.
    yer welcome :D
    EDIT: If you can wait a little while RockAuto is constantly sending me 10% off codes, I'd give you one.
  14. Nov 24, 2008 at 5:01 PM
    pittim
    Pennsyltucky
    Boujee Prius
    While I appreciate the offer, you already saved me $40! Plus I found a 5% off coupon online.
    Just ordered it for $154 with overnight shipping. Lucy, you ROCK!
  15. Nov 24, 2008 at 6:16 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  16. Nov 24, 2008 at 6:25 PM
    HerNameIsLucy
    RIP Lucy.
    DO NOT try the wire/paper clip to get the code(s) that page talks about on an 03. That only works on OBD-I vehicles. You'll fry something on the OBD-II vehicles (95 and up on Toyota).
  17. Nov 24, 2008 at 6:35 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Should I reset my CEL before or after replacing the O2 sensor?
  18. Nov 24, 2008 at 6:36 PM
    HerNameIsLucy
    RIP Lucy.
  19. Nov 24, 2008 at 11:42 PM
    Janster
    Jandy
    Lancaster, PA
    I did it on my 96 and it worked
  20. Nov 24, 2008 at 11:44 PM
    Janster
    Jandy
    Lancaster, PA
    While you are working on the truck - you should have the battery disconnected anyway. Just by having the battery disconnected and changing the 02 sensor - the CEL shouldn't be on when you're finished.
