Replacing OEM battery with larger capacity, Canada based options?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trucks2019, Aug 12, 2025.
  1. Aug 12, 2025 at 2:29 PM
    Trucks2019
    Trucks2019 [OP] Well-Known Member
    Looking for recommendations on a replacement battery with availability in Canada. Looking for a direct drop in replacement for existing harness but something with higher capacity to the OEM one.
  2. Aug 12, 2025 at 2:44 PM
    andy044
    andy044 Well-Known Member
    NH
    Black 16 TRD Sport AC 6sp
    I think we have a size 27F battery. I believe the limiting factor from simply dropping in a larger size is the OEM battery tray and tie down. Iv read about sourcing 2nd gen tray and going up a size on battery.
    Do you have a lot of draw that necceitates a larger size?
    Jakerou likes this.
  3. Aug 12, 2025 at 2:48 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Factory spec 27F battery has some pretty good CCA's. Why do you think you need more?
    Jakerou and gudujarlson like this.
  4. Aug 12, 2025 at 2:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    There are same size physical batteries with a variety of specs. Very likely you can up your specs within the same class.
    Trucks2019[OP] likes this.
  5. Aug 12, 2025 at 2:58 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I suggest not over thinking batteries. Go to the closest auto parts store and buy the one specced for a taco.
    Jakerou, 69 Jim, Tallgrass05 and 3 others like this.
  6. Aug 12, 2025 at 3:03 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My factory Battery lasted 6 years. I've had lights on, fog lights on at the same time, heater with defrost on full, seat heaters on, wipers going in ice storms, stereo w/Subwoofer blasting. Never an issue. I never saw a need to replace it with any bigger.
    This truck was built for Canadian winters as well as hotter than hell third-world driving conditions....
  7. Aug 12, 2025 at 3:27 PM
    Trucks2019
    Mainly so I can run my camp lights in my truck
    was mainly to have more piece of mind running bed lights and other electronics for a bit at camp when engine is off.
    Ngneer likes this.
  8. Aug 12, 2025 at 3:39 PM
    Buck Henry
    Understood. Then you want to find one with a higher amp-hour rating for that purpose. CCA's represent the power to turn the motor over during starting.
    Ngneer likes this.
  9. Aug 12, 2025 at 4:28 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Ever consider a solar bank? My Yeti-400 will power ( via 12v ) my CPAP Machine for days. And it powers the camper lights as well.
    My Jackery 1000 Pro powers ( via 12v ) my Dometic.
    When they need charging, bring out the solar panels.
    Then all you gotta worry about is your standard battery - Walmart Everstart is a decent battery for less money.
    69 Jim and RustyGreen like this.
  10. Aug 12, 2025 at 6:31 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Not sure about tray size for a 27F (I just replaced my 24F with a 24F) but SDHQ sells a hold-down strap that expands up considerably more that the OEM foldover bracket ... installed one of those just for grins and giggles.
  11. Aug 12, 2025 at 6:49 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    This is what I'm running in my 3rd gen, it's been fantastic. Cranks a bit faster with the AGM. Also won't spill when you're offroad. I've had it in both -40 and +40, never even noticed it.
    5 year free replacement at any Canadian Tire nation wide, and you don't need to carry the receipt for that, you just walk in with the battery, they scan the barcode on it and if you're within 5 years, you walk out with a new battery. It's nice to have if you're on a road trip away from home and it gets weak.
  12. Aug 12, 2025 at 7:27 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Don't know where you live in Canada.
    I'm in Alberta and find Costco lead acid standard size works for 5 years.
    Just replace every 5 years before it quits.
    No use or point in spending any more for something with a fancy package or name and certainly no need for AGM.
    Chew likes this.
  13. Aug 13, 2025 at 8:25 AM
    Taco_Ventures
    Taco_Ventures Well-Known Member
    N
    SL, UT
    23 Taco OR DCLB
    Honestly- if you're running a bunch of stuff when the engine is off (camp lights etc) I would use a secondary power source (house battery, power bank) to make sure you save your starter battery.
    I currently use smaller LifePO4 batteries for camp stuff, and use a DC-DC charge controller to maintain them. They fit in the space behind the rear seat pretty well.
    Or use a low-voltage cutoff between your camp lights and the battery so you maintain a min voltage on the starter battery (Amazon has them for less than 20 bucks.
    Palomar Taco, BlueRidgeFly and Chew like this.
  14. Aug 14, 2025 at 2:15 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I got a 2nd gen battery tray which drops right in with no issue. I replaced mine wit a 27F Toyota TrueStart by Interstate from the dealer. The tray is for a 2nd gen Tacoma with the towing package. I think I paid $150 total and the specs were better than the 24F.
    shakerhood and andy044 like this.
  15. Aug 14, 2025 at 4:03 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    NAPA Legend batteries are great. Bought a few of them over the years. 850 CCA :thumbsup:
  16. Aug 14, 2025 at 10:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    There's no getting around basic chemistry. Higher capacity (more watt-hours) means a heavier battery, which exasperates the inner fender cracking issue on this platform. Better to run a second battery at a different location, on the passenger side of the engine bay or in the bed.
    If you want more cranking amps for a given size, AGM battery helps.
    Palomar Taco likes this.
  17. Aug 14, 2025 at 11:28 AM
    canuck guy
    Alberta
    23TRDOR
    Some have suggested AGM. Do a search. AGM have a problem charging fully unless mods like a tune are done.
    I still say get a standard lead acid at Costco or Canadian Tire.
    With $ saved vs AGM, put it towards getting a relatively inexpensive generator to run your camping gear.
    Good investment and you can use it as a backup at home in case of power failure.
  18. Aug 14, 2025 at 11:57 AM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    Some people roll their eyes, but I've had good luck so far with Toyota replacement batteries from the dealer. While I can't confirm or refute this, I don't believe they're the same as the box store batteries with just a "Toyota" sticker slapped on. Maybe the Toyota batteries undergo further quality control at the plant. Or maybe I just take care of my batteries. Either way, I initially chose Toyota batteries for good fitment and have been surprised at how long they last.
  19. Aug 14, 2025 at 12:22 PM
    canuck guy
    Alberta
    23TRDOR
    Most batteries in US and Canada are made by 2 or 3 manufacturers with cases and stickers applied for merchant
  20. Aug 14, 2025 at 5:07 PM
    gudujarlson
    Minnesota
    Note that a typical car battery is not intended to be run low on charge. Running it low on charge will shorten its life considerably. A better fit for that use case is a deep cycle battery.
    Also, if you really are running your camp equipment long enough that you are worried about a dead battery, you should use a second battery for your camping equipment.
    That or buy a jump box and throw it your truck.
    https://no.co/gb20
    My former boat had a normal battery for starting the main gasoline motor and a deep cycle battery for running the electric fishing motor. Both were charged by the alternator on the main motor.
