Replacing OEM Factory wheels with Steelies ('19 OR)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captain_beefheart14, Jun 18, 2020.
  1. Jun 18, 2020 at 10:10 AM
    captain_beefheart14
    captain_beefheart14 [OP] Well-Known Member
    2019 Cement Off Road
    Prinsu racks, cab and top, light bar, rear and side roof rack lights, ARE Camper shell, blackout, TRD Grille, Anytime front and rear cameras, Truck bed box (DIY) Bilstein 5100 front, OME 2885 Coils, Ikon Stage 2 Rear AAL
    I'm sure this question has been asked a thousand times on TW, but I can't find the answer. I'm planning on replacing my OEM Factory Wheels on my '19 OR with Steelies. I'm not replacing the tires. Will the factory tires fit the steel spare?
  2. Jun 18, 2020 at 10:11 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yes. The tire on your spare is the same as the other 4.
  3. Jun 18, 2020 at 10:13 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
  4. Jun 18, 2020 at 10:14 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Be sure to get tapered (aka acorn) lugnuts. The factory shank-style lugnuts aren't intended to fit steel wheels long-term - there's only a small chamfer on the end.
    Also the TPMS sensors in your alloy wheels don't fit steel wheels (different mounting angle). You'll need to get new sensors and get them programmed. That is, if you care about TPMS.
  5. Jun 18, 2020 at 10:53 AM
    captain_beefheart14
    I was going to order these: https://www.ebay.com/itm/400615761156
    But it sounds like these are the wrong ones? Geez, this sounds like more trouble than its worth with getting new sensors and getting them programmed..
  6. Jun 18, 2020 at 11:44 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    These would work (3 bucks cheaper too): https://www.ebay.com/itm/273884137940
    If you want minimum amount of work just to black out everything, this is the path of least resistance: https://www.tacomaworld.com/threads...cap-inlays-and-tacoma-decals-for-sale.537257/
  7. Jun 18, 2020 at 12:00 PM
    captain_beefheart14
    Yeah, seen this route before. It'll probably be the way to go for now. I'm waiting until I need new tires to get new tires, so thinking about getting new wheels then as well instead of going this route. Thanks for the help!
  8. Jun 18, 2020 at 12:36 PM
    bizjettech
    bizjettech Well-Known Member
    Sunny Florida
    If your OR wheels were alloy, it's my understanding you will need different TPM sensors for the steel wheels -
    The alloy wheels use a 20 deg sensor and I think the steel wheels require a 40 degree sensor, if my memory is correct
  9. Jun 18, 2020 at 1:01 PM
    captain_beefheart14
    Roger. I'm going with the vinyl stickers this go-around. I'll wait a few more months and then pull the trigger on these wheels: https://fifteen52.com/collections/o...nalog-hd-asphalt-black?variant=15113773940802
    can't justify the cost on those just yet, so this will do in the meantime. I'm leaving this thread up if anyone else has this question though.
