Replacing power steering pressure line- 2002 Tacoma 3.4 4WD need some advice
Discussion in 'X-Runners' started by Ciottim, Jun 29, 2019.
  1. Jun 29, 2019 at 4:28 PM
    Ciottim
    Ciottim [OP] Member
    Any advice or videos available?
    Thanks for the help
  2. Jul 6, 2019 at 3:24 PM
    Waasheem
    Waasheem
    2007 xrunner
    I haven't had to do a tacoma yet. Generally, low pressure hose has hose clamps. High pressure one won't. What I always do is replace the low pressure one with new hose clamps, even if only the high pressure one is leaking. Take pictures, then take off the high pressure one, any place that makes custom hydraulic hose assemblies can fix you up, usually for way cheaper than a dealer part. I have them weld fittings on, so next time its a simple unscrew, screw on repair. Pictures help so they know where you'll need room for wrenches.
  3. Jul 7, 2019 at 8:08 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Use flare nut wrenches on steel lines and always hand tighten first few threads .Very easy to cross thread.
