Replacing 'Push Button' Transfer Case with 'Manual' Transfer Case
Discussion in '1st Gen. Tacomas (1995-2004)' started by forbins, Jan 26, 2011.
  1. Jan 26, 2011 at 8:08 AM
    forbins
    forbins [OP] Well-Known Member
    2007 Double Cab TRD Off-Road
    right now my transfer case is a on the fly-bush putton type and it's busted. can I replace it with a transfer case that is manual, as in no push button???
  2. Jan 26, 2011 at 8:15 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
  3. Jan 26, 2011 at 8:17 AM
    forbins
    thanks!
  4. Jan 26, 2011 at 8:28 AM
    forbins
    oh and it's a 2002 V6-TRD-5 Speed-Rear Diff Lock
  5. Jan 26, 2011 at 9:33 AM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    It will save you a shit load of money to just replace it with the original.. not to mention the hastle and work.
  6. Jan 26, 2011 at 9:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Fix what is 'busted'
  7. Jan 26, 2011 at 10:04 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Did you check the fuse and switch? Might just be a simple electrical issue.
  8. Jan 26, 2011 at 10:11 AM
    forbins
    long story short, i've spent $600 at a toyota dealership on random parts that they said would fix the problem, nothing worked, (don't know what was going on, but it was at the same time they were having all the gas pedal recalls) either way, i got ripped off big time, they said they tested all the switches and fuses etc... i hate the whole push button thing anyway and if I could, like to do it manually. i can get a transfer case online right now for $200 shipped. I'm just wondering if it will work, or what it will take to make it work.
    Supra TT you said it will save me money not to,,, please explain, why will it cost a SHIT ton of money??
  9. Jan 26, 2011 at 10:16 AM
    Janster
    Jandy
    Lancaster, PA
    So, what exactly is the problem? What exactly did they replace?
    Sounds like you should've taken your truck to another dealer before getting continually ripped off by the same dealer.
    Although I'm not totally familiar with the proces - BUT - if I had to guess.... You're gonna have to change a lot of things in the front diff area...including manual hubs and different shafts up front, etc. EXPENSIVE.
  10. Jan 26, 2011 at 10:25 AM
    forbins
    as for the dealer end of it, they told me it was different things on different occasions, i kept racking up a bill on service, but I got the run-around several times, at first they told me it was something electrical but not a fuse or switch, then they told me it was the read diff lock motor, which was BS and then they said they made a mistake and that it was the front a.d.d. motor, so i purchased that and installed it, still nothing. I'm fed up with messing with this push buttton garbage and would like to got the manual route.
  11. Jan 26, 2011 at 10:27 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    cantact member awsumduck (wyatt) I'm sure the conversion can be done.
  12. Jan 26, 2011 at 10:37 AM
    Janster
    Jandy
    Lancaster, PA
    So, what exactly is it NOT doing? I'm gonna assume its' not engaging into 4WD?
    Give us some information of whats happening....
    Have you (or they) inspected the vacuum lines that operate the system?
    Have you (or they) inspected the axle sleeve in the diff housing area?
    Did you do some research online and find out exactly how the system works?
  13. Jan 26, 2011 at 10:40 AM
    forbins
    not trying to be a dick here, don't really want to go into details of what happened,i've done all the research and whatnot, it's not engaging,
    I just want to know if I can switch out these transfer cases or not.
    searched for 'awsumduck' and it said no such user existed
  14. Jan 26, 2011 at 10:45 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    this is him. awsumdc. sorry
  15. Jan 26, 2011 at 10:55 AM
    Janster
    Jandy
    Lancaster, PA
    You haven't done enough research. Because....if you did, you wouldn't need to come here and ask about converting. There is plenty of information out there.
    You're expecting us to give you a straight 'easy' answer and that's not gonna happen. Its much more complicated than that.
    But...if you had done all your research (like you claim you have) , you'd know this already.
    **sorry man....not trying to be a dick either
  16. Jan 26, 2011 at 10:56 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    ^^ that is true dude..
  17. Jan 26, 2011 at 11:11 AM
    forbins
    look man, i've done my research you jack wagon, i didn't come here for an answer on whats wrong with my transfer case i'm pretty sure I know what's wrong with it, my question is/was can I switch the transfer case out with a manual, so if you know the answer, great, let me know, if you don't know, then beat it! jesus christ!!
  18. Jan 26, 2011 at 11:25 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Why would he need to change all these things if he is just swapping the transfer case? I have on 04 D-Cab, auto-tranny, with the manual 4X4 shift lever. I don't have manual hubs or any of the old "lock-out" style front end. As long as the case dimensions are the same, it should bolt right in. I am guessing that it might plug in to the electronics differently, and there would be a few other changes (shift lever) to deal with.
    Again, as others have said, you will have to do a search on the TW site for better information.
  19. Jan 26, 2011 at 11:26 AM
    Janster
    Jandy
    Lancaster, PA
    Thanks
    He's already got an attitude. He'll have a complex now. :rolleyes:
  20. Jan 26, 2011 at 11:28 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    You still have electronic 4Hi right? just 4lo is were you need to move the shifter?
