Replacing rear leafs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DaveEli, Jun 8, 2018.
  1. Jun 8, 2018 at 4:09 PM
    DaveEli
    DaveEli [OP] Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Getting ready to replace my AllPro Expo leafs with some Alcans. Should I replace the shackle bushings?
  2. Jun 8, 2018 at 4:47 PM
    BRONSON
    BRONSON Active Member
    Canada
    2009 TRD Sport 4x4 DCLB
    885 w/ 5100's + 1/2" d.s. top plate, EL096R w/ B110's, Whiteline LCA bushings, Energy Suspension poly leaf & shackle bushings, new OEM rear shackles, custom rear brakeline mount & e-brake extensions, LR UCA's, SnugTop cap
    They're cheap enough. Assuming they work with Alcans, Energy Suspension's poly leaf bushing kit 8.2116G includes the shackle bushings and their sticky-as-shit Formula 5 Prelube waterproof grease.
    To make it easier grab new OEM shackles from the dealer and skip the B.S. of getting the old bushings out. Part # 04005-65104 for a pair. Should be under 20 bucks.
    DaveEli[OP] likes this.
  3. Jun 8, 2018 at 5:07 PM
    DaveEli
    David
    Virginia Beach
    How bad is to get the old ones out?
    Sounds like a good idea getting new shackles.
  4. Jun 8, 2018 at 5:12 PM
    BRONSON
    Canada
    Didn't even try removing the old bushings but it didn't look particularly fun from the posts I saw on here.
    For $20 new shackles with no rust and a fresh painted surface to hopefully never squeak against the greased-up poly seemed like an easy decision.
  5. Jun 8, 2018 at 5:14 PM
    DaveEli
    David
    Virginia Beach
    Thanks.
  6. Jun 8, 2018 at 5:16 PM
    DaveEli
    David
    Virginia Beach
    Remember where you saw the posts about changing the bushings?
  7. Jun 8, 2018 at 5:28 PM
    BRONSON
    Canada
