Replacing rear suspension
Discussion in 'Suspension' started by Roadwarrior14, Oct 12, 2017.
  1. Oct 12, 2017 at 5:41 PM
    Roadwarrior14
    Roadwarrior14 [OP] Member
    My rear shocks on my 02 trd pre runner are shot and I am looking into replacing them from what I can tell when purchasing shocks they come in sets of 2 but mine have 2 on each side...IMG_7834.jpg just trying to figure out if I can buy some replacement shocks or if I need something different. Thanks for the help.
  2. Oct 13, 2017 at 1:58 PM
    Roadwarrior14
    Bump
    KiteGuam likes this.
  3. Oct 13, 2017 at 3:54 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Can't say I've seen that setup before. What other suspension modifications have been done?
    Unless you feel you need a dual rear shock setup, I would take all four out and replace them with two Bilsteins or Tokico shocks.
  4. Oct 13, 2017 at 3:57 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    If you run it over to a local offroad shop for an " estimate" they will explain your options free of charge. Then just do as they suggest
  5. Oct 13, 2017 at 3:58 PM
    tcjacado
    tcjacado Well-Known Member
    @Speed Freek Any advice for this gentleman. I am with the guy above and haven't seen a stock set up like this.
  6. Oct 13, 2017 at 4:14 PM
    eon_blue
    Azusa, CA
    Glad to know no one else has seen this setup before, lol...I saw the pic and thought maybe I got screwed with only one shock on each side on my '04 o_O
    What's weird is that they appear to be regular Bilstein 4600s? You'd think if someone was going to customize the rear setup and add dual shocks on either side, they'd upgrade the shocks as well. Subbed for curiosity...
    tcjacado and Tacomamike mike like this.
  7. Oct 13, 2017 at 4:26 PM
    Tacomamike mike
    Michael
    Custom now and custom then two different things :)
  8. Oct 13, 2017 at 5:59 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Is there something welded to the axle tube that goes towards the bottom of the diff?
    We need more pictures.
  9. Oct 13, 2017 at 6:21 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    ghetto axle truss lol
    drr[QUOTED] likes this.
  10. Oct 13, 2017 at 7:51 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    jesus i hope not.
  11. Oct 14, 2017 at 8:50 AM
    paranoid56
    San Diego
    14 double cab taco
    i think it is, It used to be super common back in the 80s.
  12. Oct 14, 2017 at 9:16 AM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    o_O. I would go with what others have said. Put it back to stock and go with a set of good shocks. If your planning on running it off of road you can talk to a shop to see what they recommend, just make sure they are reputable and know what they are doing.
