Replacing Rear window
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Climbingteach, Sep 22, 2014.
  1. Sep 22, 2014 at 11:11 AM
    Climbingteach
    Climbingteach [OP] New Member
    Park City
    06 Tacoma 4x4 TRD Sport
    New to the site. I have a 2006 4 door 4X4 Tacoma and recently smashed the rear window hauling firewood :mad:. I have called the dealer and Safelight auto glass. They are both looking for about $650 to replace the window. Anyone have a better, ie. less expensive, solution to replacing the window. Have heard that non OEM windows don't fit well and cannot find an OEM window online.
    Anyone replaced a rear window? Is it something that I can do and not have issues with or should I just suck it up and pay the $650.00.
  2. Sep 22, 2014 at 11:13 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    It's pretty simple process. Let me find you a video
  3. Sep 22, 2014 at 11:16 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    i had a local shop do mine for $350 (owner is a family friend so i prolly got cut a good deal) but the other shops wanted over $600 for it also, but the outside seals arent quite as big as the one that came out, there was a dust line that was 1/2 or so out side the edge of the new window. i think the one i got may have actually been for a 1st gen tundra or something
  4. Sep 22, 2014 at 11:21 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    I might be drunk, but I can't seem to find the video.
    Anyways the rubber piece that surrounds the outside of the window. You should be able to pull the rubber out, and the glass come out with it. Should also be able to push from the inside out. As for replacement, water and soap solution around the inside of the rubber, then push the window back in
  5. Sep 22, 2014 at 11:25 AM
    yota243
    E.J.
    north Alabama
    good luck with that. there are also a couple of 10 mm nuts on the top corners and some clips on the bottom. i couldnt get my old one out in one piece. i thought id figure out how to do it on it and go to a junk yard and just swap it out but i had to use a guitar string, razor blade, and channel locks to remove the busted one
  6. Sep 22, 2014 at 12:15 PM
    Cmane
    Cmane Well-Known Member
    Caleb
    Starkville, MS
    13 DC TSS 4X4
    I had to replace mine and went with a solid rear window instead of the split because it was about $250 cheaper. I like it and can see way better out of it
  7. Sep 22, 2014 at 12:18 PM
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    sounds familiar....
    Broke mine few months ago...Toyota wanted $1400 for OEM and safelite fixed it for $430 CASH (or about $520 with creditcard). Same lifetime warranty nationwide.....
    I think it is Pilkington glass (spelling?). It is OK in term of performance (no wind noise, no water leaks, no dust leaks...YET). On the looks side it does NOT look as good as the OEM.
  8. Sep 22, 2014 at 1:49 PM
    Climbingteach
    Park City
    Thanks for the advice. Ill let you know how it goes.
