Replacing spare cable hoist??
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, Sep 5, 2010.
  1. Sep 5, 2010 at 11:37 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Alright, so I am finally getting around to replacing my cable hoist for my spare. Thieves cut the cable to steal my spare!!!
    Anyone replaced this thing yet?
    I think I am looking at it correctly that the only way to do this is remove the rear cross member?????
    Thanks,
    Peter
  2. Sep 5, 2010 at 9:17 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i will take a look at mine tomorrow, its not being used. so if you need one pm me.
  3. Sep 6, 2010 at 9:59 AM
    RacerP
    Chicago
    2003 4x4
    I appreciate the offer, but, I already have the part. Just wondering if anyone has any experience replacing it?
    I guess MOST people don't live in a part of the country where their spare would be stolen.
    Peter
  4. Sep 6, 2010 at 11:08 AM
    98_Mud_bug
    lucedale Ms.
    yea the south is great. i can leave my windows down and my doors unlocked all the time
  5. Sep 6, 2010 at 4:22 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Should be four bolts in the corners?
    GQ7227 likes this.
  6. Sep 6, 2010 at 4:27 PM
    RacerP
    Chicago
    2003 4x4
    Unfortunately the bracket is threaded, and I believe the bolts come thru the top??
    The way I see it, the ONLY way to do it is to remove the cross member on the frame.
    I am hoping someone else chimes in here to tell me I am wrong with an easier way.
    Peter
  7. Sep 6, 2010 at 4:40 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    meh your parinoid i leave my keys in the ignition:D
    GQ7227 likes this.
  8. Sep 6, 2010 at 4:42 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    unbolt the bed and raise it up to get the bolts out
    Black DOG Lila likes this.
  9. Sep 6, 2010 at 4:55 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Ok this is what I found : On my 2000 TRD there is 4 nuts/bolts holding the cable mechanism to the cross member, the bolts/studs sticking down may be tack welded into place, even if there not try this first, spray the nuts liberally with WD-40 or another penetrating lubtricant, let it set for a bit ,then get the ratchet/extension/socket making sure its on the nut securely & give them a quick & firm "pop" to see if they break loose without spinning the bolthead on top, if this doesn't work & if yours is like mine, theres 6 nuts/bolts holding the cross member in place after you take these out, knock the passenger side of the cross member forward & it should slide enough to turn it & drop out of frame sideways avoiding rear shock mount/cables/brake lines/etc;......:cool:
  10. Mar 3, 2011 at 8:51 AM
    blackuni
    blackuni New Member
    East Coast
    2003 Black Double Cab
    Yeah, my cable rusted through and dropped my spare in the road too (2003 Dbl Cab). WTF! Luckily I was only pulling out of the driveway at the time. The lip of the driveway has a little ramp/angle to it so it must of been just enough of a bump to give away. I don't even want to think about what could've happened if I was on a busy road!
    Soooo, what's the verdict on costs for a replacement and how difficult this is to do? I haven't had a chance to get under there to look yet.
  11. Mar 3, 2011 at 9:05 AM
    EL TACOROJO
    BURRY
    south mills NORCAK
    I have the whole assembly not being used
  12. Mar 3, 2011 at 10:44 AM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    in the last 3 years i have had my truck broken into twice and my house broken into once, my buddy has his dodge stolen and broken into a few times. now i check and recheck if my truck is locked at night....i do live in baton rouge right by LSU's campus so there are a few bad parts pretty close by but its ridiculous around here sometimes
    also my tool box is locked in the bec with a cable and masterlock and spare tire holder is welded to the bed with a lock also
    OP - i have the entire assembly not being used either
  13. Mar 3, 2011 at 2:57 PM
    RacerP
    Chicago
    2003 4x4
    I still haven't gotten to this yet, fall came, and then winter, and laying on the ground trying to get this done in the middle of winter here in Chicago...not going to happen!
    So for the time being the spare just sits in the bed with the cap locked.
    At the time though, I did by a used cable hoist off of eBay for around $30
    Peter
    GQ7227 likes this.
  14. Mar 7, 2011 at 10:59 AM
    blackuni
    blackuni New Member
    East Coast
    Well I finally had a chance to get under my truck to see what the deal was. The entire spare hoist and cable are intact and fine. It was only the actual anchor part at the end of the cable that goes through the center of the spare tire to hold it up that rusted out. So for now, I think I'm going to look into maybe replacing that piece with something else to do the job of holding the actual spare. Might beat having to buy and replace the entire spare hoist unit given the potential headache that might be with the bed, etc.
    I'll upload a pic when I get a chance and see if anyone has any good suggestions on what I could use.
  15. Feb 4, 2020 at 4:11 PM
    Natenite
    Natenite Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Bumping the crazy old post. I need to know if this is doable? Has anyone replaced the hoist? Thanks!
    GQ7227 likes this.
  16. Feb 4, 2020 at 5:01 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    There is a recall on the spare hoist. Make an appointment with Toyota service mgr. Tell them you can't find the letter you were sent years ago and forgot to get it done.
    cruisedon66 and Natenite[QUOTED] like this.
  17. Feb 4, 2020 at 5:17 PM
    Natenite
    Springfield Mo
    I don’t think my truck is eligible for recalls, it is a prior salvage. I’ll reach out as see though. Thanks!
  18. Feb 4, 2020 at 5:20 PM
    Black DOG Lila
    Virginia
    It's a DOT safety recall. Toyota is obligated by court order. Get more Bees with honey though.
  19. Feb 4, 2020 at 5:42 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    mine is probably 0k but IDK, i just sprayed FF all up in all that back there seems to have helped
  20. Feb 4, 2020 at 5:50 PM
    Kerby J
    Kerby J Well-Known Member
    Kerby
    Lincolnton, NC
    1998 Quicksand Tacoma
    from my experience on 4Runner's you can get to the bolts to get them out from the top without removing the cross-member with a wrench but not the Tacoma.
    Edit: based on the response from another member I verified on my tacoma that it is indeed to tight to get the wrench up there due to the corrugation of the bed and one of the support bars. The cross-member should't be that difficult to unbolt and slide out. Guess I had the bed off when I removed it from my parts truck...
    joe25rs likes this.
