Replacing spare cable hoist??
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, Sep 5, 2010.
  1. Feb 4, 2020 at 7:03 PM
    Kerby J
    Kerby J Well-Known Member
    Kerby
    Lincolnton, NC
    1998 Quicksand Tacoma
    Since this is a constructive collaboration site and you apparently know so much, maybe in the future you could provide the answer to the question instead of a safety recall information...
  2. Feb 4, 2020 at 7:31 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    One word got you to rethink your bad advice and edit it out. Good on ya mate. :tinfoilhat:
  3. Feb 4, 2020 at 9:06 PM
    Jeremy Martin
    Jeremy Martin Well-Known Member
    1st Gen Taco
    Black DOG Lila likes this.
  4. Feb 9, 2020 at 11:15 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Use a 14mm (or 12mm) crowsfoot wrench. It takes forever, but loosen each of the four bolts 1/4" at a time. Leave enough room to get the Crowfoot out between the bottom of the bed and the top of the nut head to move on to the next bolt.
    It's a bitch. But it's less of a bitch unbolting the bed or removing the crossmember, because the crossmember and bed may not want to line up.
    I've removed my spare tire hoist w/o removing the bed or crossmember.
    Durango95 and Natenite[QUOTED] like this.
  5. Feb 9, 2020 at 11:31 AM
    Natenite
    Natenite Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Any ideas where to get a replacement hoist?
  6. Feb 9, 2020 at 11:34 AM
    License2Ill
    Ian
    Come to think of it. I used only the Crowfoot to break all four bolts loose, then used a open-ended box wrench to continue. Use penetrating oil a few days prior to attempting to remove the bolts.
    Natenite likes this.
  7. Feb 9, 2020 at 11:37 AM
    License2Ill
    Ian
    I have one that I don't want. You'll have to migrate the "key" end from your existing tire carrier because mine had the security lock, the PO didn't bother to give me the key when he sold me the truck.
    Natenite[QUOTED] likes this.
  8. Feb 9, 2020 at 12:17 PM
    Natenite
    Springfield Mo
    Unfortunate someone cut my cable so I don’t have the tire end. I only have a hoist with some unraveling cable sticking out.
    License2Ill[QUOTED] likes this.
  9. Feb 9, 2020 at 12:30 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :crapstorm: :annoyed:
  10. Feb 9, 2020 at 4:43 PM
    paetersen
    paetersen Well-Known Member
  11. Feb 9, 2020 at 5:21 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I have a 2003 Tacoma.
    Got mine replaced free by Toyota about two years ago.
    Not sure if this recall has expired or not.
    The cable mechanism unbolts from the bottom. Probably 12 mm.
    4 bolts. If you have to snap off the bolts, you can drop the crossmember and either rethread them or replace with nuts.
  12. Feb 9, 2020 at 5:33 PM
    Natenite
    Springfield Mo
    I looked in to the recall and it only applies to certain states. My truck doesn’t qualify unfortunately. I’ll need to find one if I end up trying to mount my skate under there.
    cruisedon66[QUOTED] likes this.
  13. Feb 9, 2020 at 5:36 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a horrible bitch. Even worse with a hitch installed.
    We loosen the bed off, jack it up slightly. Heat the nut and loosen the 12mm bolts with a special tool, or ratchet wrenches.
    I havent done that recall in over 3 years.
  14. Feb 9, 2020 at 6:47 PM
    paetersen
    Recalls never expire.
  15. Feb 9, 2020 at 7:09 PM
    #35
    cruisedon66
    Pete
    Near St. Louis
    I guess they only expire if they run out of parts to fix it or manufacturer goes out of business.
  16. Feb 9, 2020 at 7:12 PM
    #36
    Bishop84
    Yes they do. Many have.
    This one is still active, its USA code C0V and its 2001-2004 models.
    cruisedon66 and Black DOG Lila like this.
  17. Feb 10, 2020 at 11:02 AM
    #37
    cruisedon66
    Pete
    Near St. Louis
    November 23, 2012NHTSA CAMPAIGN NUMBER: 12V542000
    Spare Tire Carrier may Fail
    Corrosion of the plate could cause it to break, which could result in detachment of the spare tire from the vehicle. Detachment of the spare tire could result in a road hazard which may increase the risk of a vehicle crash.
    NHTSA Campaign Number: 12V542000
    Manufacturer Toyota Motor Engineering & Manufacturing
    Components TIRES
    Potential Number of Units Affected 150,000
    Summary
    Toyota is recalling certain model year 2001 through 2004 Tacoma light trucks manufactured from August 28, 2000, through August 27, 2004, and originally sold, or currently registered, in the following cold climate states with high road salt usage: Connecticut, Delaware, Illinois, Indiana, Kentucky, Maine, Maryland, Massachusetts, Michigan, Minnesota, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, Virginia, West Virginia, Wisconsin, and the District of Columbia. The spare tire in the subject vehicles is located underneath the rear of the vehicle and held by a spare tire carrier. A lift plate on the carrier is used to help raise, lower and retain the tire. During its manufacture, the lift plate may not have been sufficiently coated with anti-corrosion materials. If the plate is insufficiently coated and the vehicle is operated in cold climate regions where road salts are frequently used, road spray can reach the carrier assembly and corrode the lift plate.
    Remedy
    Toyota will notify owners, dealers will inspect the vehicle and replace the spare tire carrier lift plate as necessary, free of charge. The recall began in February 2013. Owners may contact their Toyota dealer or the Toyota Customer Experience Center at 1-800-331-4331.
    Notes
    Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov
  18. Feb 10, 2020 at 5:38 PM
    #38
    License2Ill
    Ian
    No. The "key' end. The part with the slot or key that is used via the bottle jack tool to hoist up or down the tire. That's the part you'll need from your old hoist. It's held in with a pin. Like I said, mine's missing. PO never gave me the key, so I removed it so I could remove my tire, then ended up chucking it at this annoying fucking quail. Otherwise my hoist is golden.
    Let me know, you pay shipping. It'll take me a few weeks to dig for it in my storage.
  19. Feb 11, 2020 at 5:16 AM
    #39
    Natenite
    Springfield Mo
    Oh I see. Yeah. Dig it out if you can. That would be awesome. No rush. I’ll be in Big Bend next week so I won’t be able to reply to anything but message me when you have it. Thanks!
  20. Feb 11, 2020 at 1:29 PM
    #40
    paetersen
    No. They don't. There are only 3 ways a recall can 'end', but they never 'expire'.
    1- The specified work is performed and the recall is marked 'completed' for that VIN.
    2- The company goes out of business and no other company buys it's assets/liabiities. (my Saab had it's takata airbag recall performed at an 'authorized service center' after Saab went out of business.)
    3- The parts needed to complete the recall are no longer made by the manufacturer.
    Safety recalls are completely different from voluntary Service Campaigns, such as a certain manufacturers frame 'recall'.
