Replacing spark plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeff, Jan 28, 2010.
  1. Jan 28, 2010 at 1:12 PM
    Jeff
    Jeff [OP] Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    Just a quick question, what brand of sparkplugs is everyone using these days? Toyota's or aftermarket. Thanks
    Jeff, 06, V6 SR5, 6spd
  2. Jan 28, 2010 at 1:16 PM
    JAG
    JAG Well-Known Member
  3. Jan 28, 2010 at 1:17 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    General consensus on this forum is to use the factory Denso copper plugs in the V6. Iridiums in the I4.
  4. Jan 28, 2010 at 1:21 PM
    JAG
  5. Jan 28, 2010 at 1:27 PM
    Jeff
    Hopkinton,MA
    Thanks for the great pic's and info. I was curious as to why Toyota wants the plugs out every 30K? It doesn't seem to make sense considering most plugs last a very long time.
    I had it figured it was a way of making $$ for the dealer. What do your plugs look like when you change them out? Is the gap significantly increased?
    Thanks again, Jag for the close up photo's , will make it easier in the spring.
    Jeff, 06,V6, SR5 V6
  6. Jan 28, 2010 at 1:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check out the link JAG posted. All the info you need is in it. :)
  7. Jan 28, 2010 at 2:15 PM
    JAG
    That was all thanks to Chris. Don't want to take the credit away from his great work!
  8. Jan 29, 2010 at 4:05 AM
    Jeff
    Hopkinton,MA
    Thank you Chris.
    Jeff O6, V6, SR5 6spd
