Replacing stock 2012 radio with a oem touchscreen
Discussion in 'Audio & Video' started by chrispy, Oct 19, 2013.
  1. Oct 19, 2013 at 12:41 PM
    chrispy
    chrispy [OP] Well-Known Member
    Winnipeg, Manitoba
    2012 Tacoma SR5 4X4
    I have a 2012 tacoma access cab with a stock non jbl radio, xm, bluetooth, steering wheel controls, usb. Is it possible to swap one of the oem touchscreen non jbl units from a 2013 without having to touch the wiring?
    Are there ones with the navigation that can be swapped?
    I tried searching but couldnt find a post that showed a direct swap of the units with instructions.
    thanks
  2. Oct 19, 2013 at 5:36 PM
    Solid Seung
    Solid Seung GWOT Infidel
    New California Republic
    2013 SC V6 DCSB TRD OR 4x4
    TRD Supercharger aFe Stage-2 Si Pro DRY S CAI JBA Cat4ward Shorty Headers TRD Performance Exhaust PLX Wideband Air/Fuel Sensor Module Speedhut Boost & Wideband Air/Fuel Ratio Gauges CravenSpeed Flexpod ScanGauge SGIIFFP Computer Uni Filter Mod Mobil 1 Synthetic Oil Pelfreybilt Off-Road: Aluminum Front Plate Bumper, Rigid DOT/SAE Fog Lights, Pelfreybilt Hawse Fairlead & Flipster Winch License Plate Bracket, Aluminum IFS Skid Plate, Steel Standard Rear Bumper, Smittybilt 3/4" Black D-Rings w/Daystar Isolators & Washers KB Voodoo Tailgate Cap System King Shocks 2.5 Front Remote Reservoir Coilovers SPC Light Racing UCAs King Shocks 2.5 Rear Remote Reservoir Shocks OME Dakar EL095R Leaf Spring Set Wheelers Off-Road Front SuperBumps, Rear U-Bolt Flip Kit with SuperBumps Crown Performance Red SS Brake Line Kit Body Mount Chop Tandem Off-road 612 Bravo 17x8.5” Wheels BFG T/A KO2 285/70R17 Tires Redline Tuning QuickLIFT ELITE Hood Struts Redline Tuning Tailgate EZDOWN TRD Battery Hold Down Duralast Platinum Battery 24F-AGM OEM Black Grille Bezel TRD Pro TOYOTA Grille TRD Pro Black Headlights Sylvania Silverstar zXe H4 Lamps Rain-X Silicone AdvantEdge Wiper Blades OEM Running Boards OEM Tacoma Bed Mat AJT Design Climate Control Knobs WeatherTech Floor Liners Covercraft Carhartt Precision Fit Custom Seat Covers Emergency Assistance Kit First Aid Kit Salex Organizers Center Console & Glovebox OCD Anker 36W Dual USB Car Charger PowerDrive+ 2 Type S Drive Dash Camera Garmin nüvi 255W 4.3" GPS Navigator Steadfast Auto 8" Antenna Pioneer AVH-X3500BHS 2-DIN Multimedia DVD Receiver 6.1" WVGA iPod nano 8G (6th Gen) JL Audio XD700 Watt/5 Channel Amplifier JL Audio C2-650X & C2-650 6.5" speakers JL Audio 10W1v2-4 10" subwoofers (x2) in a JL Audio Stealthbox
    I have a OEM double DIN touchscreen deck from a 2013 DCSB if you need one.
  3. Oct 19, 2013 at 7:28 PM
    chrispy
    Winnipeg, Manitoba
    2012 Tacoma SR5 4X4
    Thanks, I just need to find out whats involved with the swap, before i go ahead with the project.
  4. Oct 21, 2013 at 2:46 PM
    Aw9d
    Aw9d That one guy
    I want to say they are the same wiring harness but I've not pulled one out to check. Since Toyota has used the same harness for non-jbl HU's since the 80's I doubt its changed.
  5. Oct 21, 2013 at 2:48 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    the 2013 entune units only work with the jbl hardness/system...
    the 2013 just touchscreen non navi units, will plug in fine for power and speakers but you need to rewire the steering wheel controls, bluetooth, mic etc...
  6. Nov 4, 2013 at 11:34 AM
    warriors_03
    warriors_03 Active Member
    Mark
    San Marcos
    2012 Tacoma DCLB Sport 4x4
    Is there a thread with instructions?
