Replacing stock exhaust w/ performance system
Discussion in 'Performance and Tuning' started by Tacodino, Jul 30, 2015.
  1. Jul 30, 2015 at 8:29 PM
    Tacodino
    Tacodino [OP] New Member
    2007 Tacoma 6cyl 4x4
    Stock
    I'm planning on replacing my failing stock exhaust system with a performance one, and wondered if swapping out the manifolds with headers would be worth it. How much hp would headers actually add to a 6cyl vs replacing from the manifolds?
  2. Jul 30, 2015 at 8:35 PM
    Tacodino
    Stock
    That's exactly where I'm coming from. I don't have the money. My exhaust will have to be replaced soon and I'd just like to get the most out what I've got. (I know it's only a 6cyl)
  3. Jul 30, 2015 at 8:55 PM
    Tacodino
    Stock
    I use my truck for everything. Daily driver, landscape projects, hauling, 4 wheeling. It's my third Tacoma and I've put them to the test on occasion. They're great trucks. Somehow I have a hole developing in my exhaust pipe where a hanger broke off. I'm sure I hit something for this to happen. So if I'm going to replace the system anyways I thought I'd see what my options are. I always like to make any bolt on repairs an improvement when possible.
  4. Jul 30, 2015 at 9:04 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Subd for curiousity.
  5. Jul 30, 2015 at 9:33 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Torspeed had a post about a brand of new headers. Only ones I would buy. Find it. Pricy.
  6. Aug 2, 2015 at 9:02 AM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    for a catback, check out the dynomax kit with "ultra flo" muffler, sounds awesome.
    if you're looking for headers/y pipe and want to stay cheap, you could check out the OBX package on ebay that copy doug thorley's design. As mentioned above, the URD equal length headers are going to be the best you can buy but are very expensive.
  7. Aug 7, 2015 at 10:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  8. Aug 9, 2015 at 11:04 AM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    i agree about obx being cheap, which scares me to take the plunge and buy them. Should probably just save up and buy the good stuff from URD lol.
    MadDaddy likes this.
  9. Aug 9, 2015 at 12:02 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    No money, daily driver, little to no performance gain, take to a muffler shop weld on hanger patch hole good for another 100 k total cost around $25 Of course you will not get that deep v8 rumble but you wont get with headers either.
  10. Aug 10, 2015 at 9:30 PM
    Tacodino
    Stock
    I've been on the fence about what to do and Bubbabub is dead on! Thanks for suggesting a smart, inexpensive way to go. I'll spend the money on something I NEED to do. And THANKS TO ALL for their input. It's much appreciated!
