Replacing stock shocks with Bilstein 5100s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Woodrowski, Mar 20, 2017.
  1. Mar 20, 2017 at 1:42 AM
    Woodrowski
    Woodrowski [OP] New Member
    Hello everyone,
    I have an 09 Tacoma dbl cab 4x4 TRD Sport short bed. I've got 90K miles and want to replace the stock shocks/struts with Bilstein 5100s all around. If I have them set at 2.5 in. above stock can they just be switched out or do I have to do anything else?
    Thanks,
    Woody
  2. Mar 20, 2017 at 1:43 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Alignment is needed.
  3. Mar 20, 2017 at 1:48 AM
    Woodrowski
    thanks, Roadking1, Yes I heard that but do I need to install another leaf or block in the back or extend the brake lines or anything of that nature. I've read that on other toy sites. I had to have it aligned when I had the leafs replaced due to the recall.
  4. Mar 20, 2017 at 2:11 AM
    Woodrowski
    It looks like everyone is recommending .85 or 1.75, any higher you start running into trouble. I'll keep reading.
  5. Mar 20, 2017 at 2:32 AM
    roadking1
    n.j.
    I put mine at 2.5.No issues.It sits level.I had the recall springs done after.I bought 1 inch blocks for the rear but I returned them.They were unnecessary.
  6. Mar 20, 2017 at 3:12 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    If you go 2.5 buy a mouth guard. It's going to be stiff as f**k
  7. Mar 21, 2017 at 11:40 AM
    tacomatyler
    tacomatyler Well-Known Member
    Tyler
    Kansas City
    2017 TRD Sport
    5100s & 884s, AAL, PRO SEMAs, Toyo ATs
    I did mine this past weekend. 0.85 notch with the taco lean 1/4" spacer and my DCSB Sport sits perfectly level after alignment. TSB leaf springs also done 2 months ago. I was very surprised how high the 0.85 clip actually lifted the front. I'm glad I didn't go higher.
  8. Mar 21, 2017 at 11:55 AM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    Just replacing the shocks in the rear will not give you any lift back there, in order to get a lift in the rear you'll need to get an AAL, see leaf packs, or blocks. Setting the front at 1.75 on stock coils will level the truck.
    My old setup, 5100s at 1.75 up front on stock coils, nothing in the rear.
    tacomatyler and Fastbilly5 like this.
