Replacing stock shocks.
Discussion in '1st Gen. Tacomas (1995-2004)' started by bbernosky06, Feb 12, 2009.
  1. Feb 12, 2009 at 11:15 AM
    bbernosky06
    bbernosky06 [OP] Member
    Central FL
    1999 Tacoma SR5 4x4 TRD
    3" Body Lift Rancho Quick Lift Suspension
    Getting ready to replace the shocks in my truck. Is there any problems that anyone had while trying to do so. Trying to figure this out so I know what I am dealing with
  2. Feb 12, 2009 at 11:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just take the front ones to a shop if you dont have a wall mounted spring compressor.
  3. Feb 12, 2009 at 4:37 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The rears are a direct take off and put on. And like Chris said, take the front setup to a shop with a spring compressor to have them put on the new shocks for you. When you take off the front ones, just take off the 3 smaller nuts on the top and DO NOT REMOVE THE LARGER MIDDLE NUT, it holds the shock in place, if you remove that there's a possibility that the shock may shoot out and that could be ugly.
  4. Feb 12, 2009 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What he said^^^^^^^^
