Replacing Stock Suspension with 4600s - Springs?
Discussion in 'Suspension' started by adamant365, Nov 29, 2018.
  1. Nov 29, 2018 at 8:51 AM
    adamant365
    adamant365 [OP] Well-Known Member
    Adam
    Kentucky
    '09 SR5, DCSB, 4x4
    Hello All,
    My Taco is having the frame replaced soon. I have 114K miles and figure I might as well go ahead and replace the suspension components. Dealer doing the frame will install free since the old come off anyway. Currently it's stock SR5 (black - Tokicos?). The rear leafs were replaced about 15K ago with the recall. I'm thinking about upgrading to 4600 HDs on all four corners. Which coil spring should I consider? I'm not looking to lift (ever), just improve ride quality.
    I've spent lots of time searching here and can't seem to find good suggestions for springs while also maintaining stock heights.
    Thanks!
  2. Dec 12, 2018 at 8:08 AM
    adamant365
    Adam
    Kentucky
    '09 SR5, DCSB, 4x4
    Let me rephrase the question after I've done some research into aftermarket and OEM springs...if I put 4600's on all four corners and use OEM TRD Off Road springs, will I notice an improvement in ride/handling over my stock SR5 setup? Or should I use OEM SR5 springs with the 4600s? I'm basically looking for less nose dive on braking and improved ride and handling without having a harsh ride.
  3. Dec 12, 2018 at 12:46 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    The stock TRD off road suspension is 4600's with the TRD off road spring (not sure if it's different than the SR5 spring). So the ride will be identical to a stock trd off road truck. Mine had nose dive when breaking.
  4. Dec 13, 2018 at 10:32 PM
    T6A1C9O
    T6A1C9O Well-Known Member
    San Diego, CA
    2017 SW DCSB TRDOR 4x4 w/Tech
    The stock OR suspension uses a 36 mm piston shock built by Bilstein to Toyota specs and packaged to look like a 4600. The 4600s will have higher oil volume/heat rejection capacity and will ride a little stiffer than the stock OR shocks.
  5. Dec 13, 2018 at 10:42 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    As far as coils, off-road are progressive
    Sr5 and sport share the same linear coils.
