Replacing the AC unit in my home - Requesting advice from any home AC guys on here
Discussion in 'Off-Topic Discussion' started by ramonortiz55, Dec 1, 2017.
  1. Dec 3, 2017 at 7:38 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    HVAC contractor here, own a Trane dealership.
    Nothing wrong with flushing, like everything else, just needs done properly. It is an approved method by all major manufacturers. I haven't changed a lineset in years. The time saved by flushing matters to me. And on startup, if the flushing is done poorly, the pressures will reflect that. I have never seen it be an issue, but I use flush and nitrogen like it's going out of style. I also love my vacuum pump, because well, it was expensive and I want my moneys worth out of it.
    Of your quotes, i'd say the Amer. Stan is my fav so far. I do not like Goodman equipment, or Ruud/Rheem. That being said, it's mostly preference. The single most important aspect of the job is that it is done well. If the best equipment in the world is put in poorly, it will run as such. Crappy equipment put in well will do as well as it can.
    The reason Goodman equipment is popular is because it is cheap. Landlords use it. It's not inherently bad, a couple of years ago, consumer reports had a run down of brand reliability and they all were within spitting distance of each other. Brands like Carrier and Trane do get higher spec stuff from the manufacturers though.
    I've worked for Lennox, Carrier, Bryant, York, Goodman, Janitrol, Water Furnace, Mitsubishi, and others before I started my own company.
    Single stage AC is my preferred AC, 14 SEER is plenty, it's going to be 40% more efficient (on paper) than your current unit, the 16 SEER is unnecessary and your ROI on it may not make sense. You're in Texas though, so it may be different than where I am. For gas heat I love a 2 stage with a variable speed blower, it's the most popular setup I sell. I don't care for full variable furnaces and with you being in Texas, no way the ROI makes sense.
    Also, none of this new stuff is made like it used to be (shocker, I know), so don't expect 40 years out of it lol.
    Extra Hard Taco likes this.
  2. Dec 3, 2017 at 7:41 PM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    do you like the American Standard quote because?...
    Is it a good brand for ACs? I didnt know they made ACs.. Im a plumber by trade so I relate AS to sink and toilet fixtures.
    How are the parts for the units?
  3. Dec 3, 2017 at 7:44 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Parts as in availability and pricing
  4. Dec 3, 2017 at 7:47 PM
    Lt. Dangle
    Ohio
    Amer. Stan. is quite similar to the Trane. Parts cross fit between them readily.
    Lol its the same thing. I actually looked into getting an A.S. dealership when I started my business, but Trane found me.
    No way a Goodman quote should be close. I can get a full Goodman setup for about $1300 or so. You couldn't pay me to put a Ruud/Rheem in my house.
  5. Dec 3, 2017 at 7:48 PM
    Lt. Dangle
    Ohio
    Parts can be had at any A.S. or Trane dealer so it depends on what is in your area, but it gives you multiple chances.
  6. Dec 3, 2017 at 7:50 PM
    Lt. Dangle
    Ohio
    And why is your one quote a 4 ton if you currently have a 3 ton? Did anyone do a load calc? Oversizing your AC is the worst thing you can do.
    Capt Jrod likes this.
  7. Dec 3, 2017 at 7:51 PM
    ramonortiz55
    Ramon
    Texas
    stock
    goodman .. quote close to ...?
  8. Dec 3, 2017 at 7:52 PM
    Lt. Dangle
    Ohio
    EDIT: As for pricing, depends on the dealer, but typically premium brands carry premium prices. I'm a small contractor, so I can undercut the big guys all the time. Again, depends on the dealer.
  9. Dec 3, 2017 at 7:52 PM
    ramonortiz55
    Ramon
    Texas
    stock
    i have no idea. he probably mistyped or misinterpreted my existing unit
  10. Dec 3, 2017 at 7:53 PM
    Lt. Dangle
    Ohio
    Goodman - 14 Seer - $5200 Installed
    16 Seer - $6500 Installed
    American Standard - 14 Seer - $6200 Installed
    16 Seer - $7200 Installed
    From your first post on the quotes you got. Most dealers have an entry level product, then a premium brand, that seems to be what contractor #1 quoted you.
  11. Dec 3, 2017 at 7:58 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Got it
  12. Dec 3, 2017 at 8:01 PM
    Lt. Dangle
    Ohio
    Honestly, your best bet is to do your homework and research your dealers. It's a tough task, reviews can be gamed, yelp and angies list are bought and paid reviews, but doing some legwork can help you out.
  13. Dec 3, 2017 at 8:04 PM
    ramonortiz55
    Ramon
    Texas
    stock
    thank you for your advice
  14. Dec 3, 2017 at 8:05 PM
    Lt. Dangle
    Ohio
    Good luck.
  15. Dec 4, 2017 at 6:12 AM
    #35
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    As long as the existing line set is the right diameter for the equipment it can be reused. Remember distance between equipment can change the diameter. Also put in a filter drier to be safe. Be damn sure he uses a micron gauge to be sure the vacuum gets down below 400. Flush the hell out of it and make sure there aren't any low points or loops.
    ramonortiz55[OP] likes this.
  16. Dec 4, 2017 at 6:17 AM
    #36
    Capt Jrod
    Jarrod
    Northern Ohio
    I tell people to call the supply house and ask for a reputable private guy. When the owner does the install you get a better product with less overhead to pay for. I don't advertise and pretty much live off word of mouth. Contractors hate the b.s. More than customers. No I don't take charge cards, I don't have 6mos same as cash. Yes you can help me demo and set the new equipment. I always have low bid because it's me my buddy and a truck. We are licensed and insured. The big name on the door with the fancy office is installed by a $16/hr guy who has been there for three months.
    sjwhitaker likes this.
