Replacing the Air Filter, What do you recommend?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MedlinAround, Jul 13, 2011.
  1. Jul 13, 2011 at 9:34 AM
    MedlinAround
    MedlinAround [OP] Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Stopping by Advance Auto when i get off of work to get me a new airfilter for my truck. It's an 08 and is getting ready to roll over 40,000 Miles. Whats something that you all have experienced. Would like to get the whole intake kit but believe i am just going to replace the filter.
  2. Jul 13, 2011 at 9:40 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yea, I'd just get an oem replacement. Nothing wrong with it.
  3. Jul 13, 2011 at 9:48 AM
    MedlinAround
    Cody
    Kentucky
    Don't think the K&N will maybe upgrade my MPG a tad or do just the same as the OEM ?
  4. Jul 13, 2011 at 10:06 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I put a TRD in mine only because I got a deal on it, no noticable changes in sound, power, mpg, etc. One could argue that some are better filters but the stock ones work just fine.
    But... if your heart is set on aftermarket, I'd go with TRD or AFE.
  5. Jul 13, 2011 at 10:20 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have not seen any dust past my AFE dry filter? Maybe the 4cyl filter fitment is different then the 6cyl? So far, I do not miss a oil type filter at all. :cool:
  6. Jul 13, 2011 at 9:38 PM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    I had dust past the filter also after some dirt roads,Stock box with AFE pro dry. Got a K&N all is good no more dust.
  7. Jul 13, 2011 at 9:40 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I would go with stock.
  8. Jul 15, 2011 at 5:50 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Same here. Checked my AFE Pro Dry filter and found it wasnt sealing correctly with the stock filter box and noticed some dust inside past the filter. Went back to the stock filter. Anyone want to buy a used AFE?
  9. Jul 15, 2011 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All other things being equal, perhaps. However, oiled gauze filters filter more poorly than any dry filter available.
  10. Jul 15, 2011 at 6:06 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    A lightly oiled oem will certainly filter better than a dry oem. :cheers:
  11. Jul 15, 2011 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And drag racing vehicles have no filter.......flow vs. longevity. After the race, the motor is re built, or inspected/tested before the next one. Many of the vehicles I have been around that raced off road, ran K&N type filters, with no oil. Sure they didnt filter as good, but the oil didnt attract the dust, and gum up the filter. Whats 1000 miles to an engine thats gonna be rebuilt soon after? As long as the larger debris is kept out, more flow, the better....Not a good thing on a vehicle expected to last for many years.
  12. Jul 15, 2011 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No doubts there..
  13. Jul 15, 2011 at 6:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And, FWIW, Off road working vehicles use dry filters. Many use a 2 filter design, with a Primary, and secondary filter......and they are very large.
