Replacing the factory JBL speakers without adding another amp
Discussion in 'Audio & Video' started by KileBillyV, Dec 28, 2022.
  1. Dec 28, 2022 at 8:31 PM
    KileBillyV
    KileBillyV [OP] Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro
    I'm currently already in the process of having a 12" ported sub + 600w mono amp + lc2i installed. I've been looking around trying to find the best speakers to replace the factory jbl's with. Something simple with not much modification. I think the stock jbl speakers are something like 2 ohms. If anyone also has a recommendation for replacing all 6 speakers + an amp solution I'd like to hear as well, but I'm more looking for just simply replacing the speakers.
  2. Dec 29, 2022 at 4:57 AM
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    you don't find the system as it is, with the stock amp, to be lacking in power? a new set of 2 ohm speakers are likely to have a hard time keeping up with that sub/amp.
  3. Dec 29, 2022 at 9:22 AM
    KileBillyV
    I would get an amp as well if it was that easy, thing is with the jbl system I have to buy the $350 pac amp pro just to keep my stock head unit working if I want to add another amp for the speakers. Like I said though if anyone has a good recommendation of replacing all the speakers + new amp I’d consider saving for it.
  4. Dec 29, 2022 at 9:24 AM
    KileBillyV
    This may be a stupid question idk, but since I’ll no longer have the stock sub on the amp could I put any of that power towards the speakers?
  5. Dec 29, 2022 at 11:54 AM
    D. Lengua
    '21 Limited LB
    i don't believe so.
    yeah, i'm in the same boat with JBL. i'm presently accumulating the pieces, i have an amp and most of the speakers so far, but haven't started installing. i need to get the Pac AmPro, a dsp and sound damping etc before starting.
    i've read threads here from a couple people that just replaced speakers and seem to have found some improvement with that alone. but i find that for some music i'm maxing what the stock amp can put out power-wise. so... i elected to go whole hog. incrementally upgrading by starting with speakers would likely lead me to redundant purchases given how limited the choices are in 2 ohms. while the whole project is going to be expensive, i'd still rather not throw any of that $ away.
  6. Dec 30, 2022 at 5:15 AM
    D. Lengua
    '21 Limited LB
  7. Jan 17, 2023 at 10:44 AM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
  8. Jan 17, 2023 at 11:10 AM
    KileBillyV
    I ordered the jbl 963 and jbl 628 door speakers after looking at your thread. Will this be an improvement over stock in volume and clarity by just replacing the speakers? I already have a ported 12” sub which really overpowers the speakers and if I turn them up too much to keep up they sound worse.
  9. Jan 22, 2023 at 7:02 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    if you've got the jbl amp, it won't be the head unit restricting things. it'll be a restriction at the amp, of which replacement sort of defeats the purpose of this thread.
  10. Feb 2, 2023 at 1:14 AM
    bonifacio
    Central PA
    Nah. I think it's the simplicity of just swapping things while retaining the JBL amp. It definitely is the head unit. The garbage Chinese Android unit I had would hurt my ears. The factory JBL is quiet.
    It might just be a mind thing where I think it's better. How did you install the sub?
  11. Feb 2, 2023 at 8:49 AM
    KileBillyV
    Custom ported box across the whole back wall with a little space to mount the stock amp back there as well. Alpine type s 12”. Alpine s-a60m and Lc2i mounted under the drivers seat.
  12. Feb 3, 2023 at 6:07 PM
    chinoxmk22
    chinoxmk22 Well-Known Member
    Mario
    2023 Tacoma
    If I’m understanding this correctly, to add a diff amp and retaining the stock head unit, I’d need the pac amp pro?
    I’m mainly wanting to replace the stock sub so that it hits a bit more vs the stock.
  13. Feb 5, 2023 at 7:08 AM
    soundman98
    NW Indiana
    you should be able to use the sub wiring as a speaker level input to an aftermarket amp. if all you're looking for is more bass. it won't change the eq, or make it sound better per-se, but will allow you to make it louder with aftermarket gear.
    but any removal of the jbl amp is going to require a maestro/pac amp pro, or similar, as the amp gets a 'raw' digital signal from the head unit, then adds in the channel/factory eq settings, and you need a way to decipher that signal if the amp isn't there.
  14. Feb 12, 2023 at 12:21 AM
    bonifacio
    Central PA
    So it was the head unit restricting loudness. Dropped in the Sony and it's significantly louder like the other Android unit.
    soundman98[QUOTED] likes this.
