Replacing the horn assembly
Discussion in '1st Gen. Tacomas (1995-2004)' started by kilobravo, Dec 10, 2013.
  1. Dec 10, 2013 at 8:14 PM
    kilobravo
    kilobravo [OP] New Member
    Kyle
    Austin
    99 xtra 4x4
    Hey all, newb Tacoma owner here. Bought a 99 ext cab 4x4 this weekend and I need to fix the horn to pass inspection. Mechanic told me its the horn assembly and said it would be $150 for the part, $150 for labor...so I found it online for $61 and now need to put the bad boy in myself.
    I haven't had any luck finding a thread on replacing stock horns(although it seems like i will be underwhelmed by the sound). Does anyone have any help for me? I found tidbits of info about disconnecting the battery and avoiding yellow wires since they attach to the airbag, but am somewhat at a loss at where to begin. Anything helps and is much appreciated!
  2. Dec 10, 2013 at 8:16 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    The actual horn on front?
  3. Dec 10, 2013 at 8:42 PM
    Madjik_Man
    Colorado Front Range
    Remove the grille. There are 7 or so tabs/clips holding it on. You'll see the horn mounted on the core support on the passenger side.
    Unclip the wire harness going into the horn, unbolt the horn from the core support, swap in new one, insert wire harness into new one, put grille back on.
    That's the gist of it.
  4. Dec 10, 2013 at 9:58 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    You should seriously consider replacing it with something less feminine.
    I'm embarrassed to use my horn. Its a feeble "meep meep" noise...
  5. Dec 11, 2013 at 9:10 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
  6. Dec 11, 2013 at 7:06 PM
    Madjik_Man
    Reminds me of the video a poster here made for his horn replacement thread.
    One of my all time favorite posts:
    http://www.youtube.com/watch?v=LuzF0GGIDL8
  7. Dec 12, 2013 at 3:12 PM
    kilobravo
    Kyle
    Austin
    99 xtra 4x4
    Thanks for all the help! As soon as the assembly gets here I will try the install. Hopefully I didn't order a roadrunner horn...:-/
  8. Dec 12, 2013 at 3:46 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Thinking the "General Lee" horns or a train horn mounted in the spare tire location with a compressor and reservoir tanks.
