Replacing the serpentine belt at 222,000km
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DayStars, Dec 1, 2014.
  1. Dec 3, 2014 at 5:14 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Good job!
  2. Dec 3, 2014 at 6:25 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The whole idea of the spring-loaded tensioners is that they are self-adjusting - no re-tensioning is needed or possible.
    On other belt systems with a manual adjuster, then yes, its great advise. On a Tacoma and most modern vehicles with spring tensioners not so much.
    Another note - rather than wedging the tensioner in the released position, there is a hole in both the spring-loaded side of the housing and the fixed housing. The idea is, you crank the tensioner back, pin it in the released position, remove and reinstall you belt, then take the tension off the pin with your wrench and remove the pin. If you weren't aware to look for this feature, you certainly wouldn't see it though.
    asuchemist likes this.
  3. Dec 5, 2014 at 5:19 PM
    DayStars
    DayStars [OP] Well-Known Member
    benn
    Edmonton
    07 Tacoma TDR 6spd DCSB
    Haha, i just found this out after doing the job. I looked thru a page i had open but didn't read all the way thru and found this….
