Replacing the spacers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lcedric, Nov 25, 2019.
  1. Nov 25, 2019 at 12:03 AM
    Lcedric
    Lcedric [OP] Member
    whats up everybody,
    I just got an 04 Tacoma stock. I already bought my rough country 6” lift kit but I was wondering instead of putting in the spacers on the existing springs. Would it be possible to put coilovers up front with the rough country kit? Would I still have the same 6” lift? Would it give couple more inches if so should I add extra leaf for the back? I don’t mind going higher. Lmk what should I do
    Thanks
    Taco critter likes this.
  2. Nov 25, 2019 at 8:11 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Return the kit.
    agalloch07, Wixo and Rachelsdaddy like this.
  3. Nov 25, 2019 at 9:30 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    whatstcp and Rachelsdaddy like this.
  4. Nov 25, 2019 at 12:36 PM
    Lcedric
    Lcedric [OP] Member
    yeah that’s the kit. What’s wrong with it?
  5. Nov 25, 2019 at 1:49 PM
    jbrandt
    Justin
    Well, for starters, you are replacing a majority of the critical suspension components on your truck with the cheapest kit on the market. There is a reason other 6" kits cost double, or triple what this one does.
    That kit cuts just about every corner possible in order to minimize costs. Instead of using redesigned spindles and upper/lower control arms, it simply uses spacers that attach the upper ball joint to the spindle which increase the leverage on those components which will negatively affect the reliability of those parts.
    If you are on a budget and want to lift your truck, stick to a 3" lift or less. 3" kits are less "invasive" (don't need to hack up your frame/cross members to install) and for the SAME price, you actually end up with a higher performance suspension system. Sure, you might need to do a little hammering on your fenderwells to fit 33's, but a hammer costs like $10 at Home Depot, lol...
    Other advantages to a 3" lift is that your center of gravity is lower, which is what you want for off-roading. Those sky-high trucks tend to tip over and roll more easily. Even a moderately well designed 3" suspension system with good coil overs and good springs will out perform *any* 6" lift on the market.
    If you only have about $800 to spend on your suspension, I would suggest this setup:
    (these links may NOT be exactly what fits your truck, just examples):
    Bilstien 5100s on all 4 corners. - $175 - $165
    OME 882 Coils: - $180 $380
    That's $900(ish)
    You could save some cash by getting an add-a-leaf and maybe a shackle instead of an entire new leaf pack. Another way to save money is to re-use your stock coil springs and use the 5100s to to the lifting.
  6. Nov 25, 2019 at 1:55 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Every single thing he just said.
    whatstcp and eon_blue like this.
  7. Nov 25, 2019 at 1:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If only our significant other would come to the same conclusion when we tell them what we're doing to our vehicles.
  8. Nov 25, 2019 at 2:03 PM
    jbrandt
    Justin
    "You spent HOW MUCH on shocks???"
    TacoBike, whatstcp and Das it mang like this.
  9. Nov 25, 2019 at 2:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, I couldn't tell her how much I paid I just said "I got them as part of a group buy!" (which was true)
    whatstcp likes this.
  10. Nov 25, 2019 at 2:11 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    "But babe, they were on sale. We can use the $500 I just saved on the shocks, to by a new HAM radio base unit for the truck"
  11. Nov 25, 2019 at 2:15 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    My wife pretty much knows she'll never get a straight answer on prices for anything on the truck (or my guns) lol
    TacoBike likes this.
  12. Nov 25, 2019 at 3:57 PM
    jbrandt
    Justin
    @Lcedric we aren't trying to be mean here (at least I'm not, lol), even though we are throwing some laughs around.
    I'm not your mom here, so I'm not going to tell you not to run this kit. You just need to have appropriate expectations for what this kit is. i.e. it's the cheapest kit you can buy.
    It's just that we see these kits a lot. They are quite honestly more trouble than they are worth. It's designed to re-use your stock coilovers, so literally the only thing this kit does for you is make your center of gravity higher. YOu can fit 35's with far less lift (though you do have to trim the fenders). With a 6" lift, you end up with alignment issues, the drive line angles are screwy and you even risk pulling the rear driveline out at full extension. And because it uses a block lift in the back, you tend to get bad axle wrap too.
    El Taco Diablo and Rachelsdaddy like this.
  13. Nov 25, 2019 at 4:13 PM
    Lcedric
    Lcedric [OP] Member
    it’s all good, wish I came here first before buying them. It’s always good to get some advice tho.
  14. Nov 25, 2019 at 4:14 PM
    Lcedric
    Lcedric [OP] Member
    How could I achieve a better lift with the same 6”
  15. Nov 25, 2019 at 4:18 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I think you can search the site, type in 6” lift.. there’s some funny crap in there too lol. Good luck
  16. Nov 25, 2019 at 4:19 PM
    Rachelsdaddy
    Southern NH
    At least it ain’t a Trail Master...
  17. Nov 25, 2019 at 4:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Real question; why do you need 6" of lift?
    Optimal lift for our trucks is 2"-3"; this works exceptionally well for off-roading as our trucks are plenty capable. Add in some quality tires, the ability to air up on demand, and you're ready for the trails you didn't think you could conquer.
    Even stock Tacoma's fair pretty well.
    El Taco Diablo likes this.
  18. Nov 25, 2019 at 4:37 PM
    jbrandt
    Justin
    Spend 3 grand:
    https://fabtechmotorsports.com/product/6-performance-system-w-performance-shocks-k7002/
    This kit STILL uses a block lift in the back, and the shocks are at best "okay" shocks.
    A better question is why do you need a 6" lift?
    Give me 3 grand and I'll design you a pretty bad ass 2-3" system that will run circles around any 6" lift.
    True, but I didn't think you could buy those any more, can you?
    2JHilux and whatstcp like this.
  19. Nov 25, 2019 at 4:40 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The ONLY way I would lift a Tacoma 6 inches is with a solid axle swap.
    You can make any Tacoma very capiible with just 3 inches of lift.
    Rachelsdaddy likes this.
  20. Nov 25, 2019 at 4:41 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    This man speaks the truth.
