Replacing Tie Rods
Discussion in '1st Gen. Tacomas (1995-2004)' started by gatrapper, Oct 28, 2014.
  1. Nov 21, 2014 at 10:00 AM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    They quoted you over $700 to remove outer tie rods?!?! If you purchased an entire new steering rack it would not be that much. You could get a new one, that includes inner tie rods, and put new outer tie rods on for maybe half that. So even if those outer rods were so froze up even God himself could not lose them, pffft, you could cut off the old and put in new. But you don't need to.
    Frozen in the knuckle or on the steering rack? If steering: Use PB blaster. Soak them a lot for awhile. Tap around the connector to cause vibrations and allow a little to trickle in the threads. Then spray more PB blaster. Then get two good wrenches and go to town. Put a pipe over the end of each if you want to increase the fulcrum and max your torque. You will get them lose.
  2. Nov 21, 2014 at 2:02 PM
    Tiki Tacoma
    Tiki Tacoma Well-Known Member
    CT
    03 dbl cab trd
    My friend Actually just reccomended doing the same thing. Im gonna soak it for the next 2 or 3 days then see if i can mess around with it. They were charging 200$ for labor which seems hilarious if this OP did it in 50 minutes his first time.
  3. Nov 21, 2014 at 2:23 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    if you have a welder you can take the inner tie rods off with an impact real easy..
