Replacing timing belt
Discussion in 'Technical Chat' started by john62, Jun 2, 2010.
  1. Jun 2, 2010 at 8:24 AM
    john62
    john62 [OP] New Member
    Los Angeles
    04 4X4 double cab V6
    I have a 2004 4X4 quad cab with the V6, 5VZ-FE engine. I'm due for the 90K mile service, which includes having the timing belt replaced. The local dealership is quoting $248 for the timing belt. I spoke on the phone with a highly recommended ("excellent mechanic, honest, and reasonable prices") mechanic who said it would run around $600 because he claims that there are water pump seals, etc. in there that should be replaced at the same time, and that the dealership will probably make the same recommendation once they're in process, which would increase the cost significantly.
    Is he feeding me a line, or is this a legitimate recommendation?
    Thanks for any advice you can give.
  2. Jun 2, 2010 at 9:26 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    It is a very legit recommendation. The tech is trying to save you money in the long run. Your water pump is driven by the timing belt, so doing the timing belt AND water pump at the same time is cost effective.
    Otherwise, you pay x amount of labor to do the timing belt only, then soon afterwards need to replace the water pump, paying the same labor to remove the timing belt again.
    On the 5vz-fe (3.4l), i'd say 8 out of 10 times during a timing belt change, there is coolant leaking out of the water pump. If you want to inspect it yourself, look for pink crust in between the timing cover and thermostat, or under the crank pulley/harmonic balancer. If you see pink crust, that is seepage from your water pump. Id also change the thermostat at the same time.
  3. Jun 2, 2010 at 10:25 AM
    john62
    Los Angeles
    Great! Thanks so much for the info, it's what I thought, but wanted to make sure.
    Cheers,
  4. Jun 2, 2010 at 10:36 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Glad I could help!
    -Brian
