Replacing tires
Discussion in 'Wheels & Tires' started by glwood6, Jul 5, 2009.
  1. Jul 5, 2009 at 12:00 PM
    glwood6
    glwood6 [OP] Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    This go round, wanted to get the best all around tire, that would perform on the highway AND off-road, and am partial to A/T tires. I noticed on TireRack.com's survey of top A/T tires that they list the Firestone Destination A/T ($119) first, Goodyear Wrangler SilentArmor ($167) second, Michelin LTX AT/2 ($166) third, and the Bridgestone Dueler A/T Revo ($139) fourth.
    I had been leaning towards the Michelins, having heard a lot of good things about them over the years, but never had a set, and was wanting to try them. However, it's hard to ignore this survey, with millions of road miles behind it, plus the fact that the Firestone Destination A/Ts are $47 per tire less than the Michelins...
    For those who might have had both, how do the Firestones rank in your opinion compared to the Michelins as far as road noise and tread mileage?
    Not interested in BFG A/Ts, ran those for years, and they are a good tire, just wanted something different.
  2. Jul 6, 2009 at 6:17 AM
    glwood6
    Gary
    Albuquerque, NM
    Anyone?
  3. Jul 6, 2009 at 6:24 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Everyone that has run revos loves them. I would think about Nitto Terra Grapplers or the Firestone Destination A/Ts.
  4. Jul 6, 2009 at 6:28 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    Michelins will last you the longest IMO I wish I had the money for them when I bought tires. I know people that repeatedly get over 70,000miles with their michelins.
    .....hmmmm, maybe they didn't tells us something like that toyota secretly makes michelins
  5. Jul 6, 2009 at 7:10 AM
    Hot Tamale
    Hot Tamale Well-Known Member
    Pat
    Henderson, NV
    2012 Access Cab 4x2
    Michelins for sure!
  6. Jul 6, 2009 at 7:11 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    might get more of a response if posted in the TIRES/Wheels section of the forum
  7. Jul 6, 2009 at 10:51 AM
    glwood6
    Gary
    Albuquerque, NM
    You are entirely correct. I totally spaced this one out. I spend 99% of my time on 1st Gens, so I completely forgot about wheels and tires...would some generous moderator move this thread to that section...?
  8. Jul 6, 2009 at 10:58 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    the firestone is a good tire
    the bridgestone revos are great
    if you can hold off till 1st ot the yr B/S
    has the revosA/T 2
  9. Jul 6, 2009 at 3:25 PM
    glwood6
    Gary
    Albuquerque, NM
    What's the difference going to be between the A/T and the A/T2? Is there a write-up I can read?
  10. Jul 6, 2009 at 3:59 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    Not meant to hi-jack your thread:
    I just bought some Goodyear Wrangler TDs. There is some sale going on with them. They look nice, fairly aggressive but not too bad. I paid $115 each, mounted, balanced, etc. I think it is a good price.
    Should I be concerned with a change in tire size from 265/70-16 to a 265/75-16? I don't think that I will have a big change in fuel economy/performance. What is y'alls input?
  11. Jul 7, 2009 at 10:10 PM
    glwood6
    Gary
    Albuquerque, NM
    It's not that hard to start a thread if you have a question.
  12. Jul 7, 2009 at 10:22 PM
    pittim
    pittim mittip backwards
    Pink slider.
    Revo 2s are out I think. They are on tirerack atleast.
    also check out Cooper tires.
  13. Jul 7, 2009 at 10:36 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Whatever you decide. I would buy them from Goodyear or Costco, they come with lifetime bal,rotate, & road hazard.
    Goodyear I think can get any brand from the warehouse. I found they were a couple hundred cheaper than tire rack. Where tire rack screws you is the shipping & installation($200 for 4 tires). Yeah initially the tire is little bit cheaper.
    I was going to get the BFG G-Force tires again. But they were $1300.
    So I went with the Nittos. Great tire! 30k miles and they don't look worn.
    I was able to get 20" Nitto's NT420's installed with lifetime rotate, balance & road hazard for around $800
  14. Jul 8, 2009 at 5:55 AM
    pittim
    Pink slider.
    I thought costco only carried BFG and Michelin?
  15. Jul 8, 2009 at 6:08 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    And last time I checked Costco only sells stock size tires for example I wanted to get some BFG A/T and they won't sell me 265/75R16's just the stock size 265/70R16's.
  16. Jul 8, 2009 at 11:18 PM
    glwood6
    Gary
    Albuquerque, NM
    The Michelins and the Revo2s are right at the same price, so that would be a toss up. Unless I could find them somewhere locally for less. Costco has the Michelins, but they are right around the same price. I guess I was wondering if the Firestone Destination A/Ts were a good tire for the price...
  17. Jul 8, 2009 at 11:27 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I have had excellent luck with the Yokohama Geolandar A/T-S. I was a little skeptical at first as this was the first pair of Yokohama's I have ran, but the tires are awesome. I have the truck off road on a regular basis running over downed mesquite limbs and sharp rock as I work for a developer. I have yet to have any sort of issues with them and already have 20k miles on them. The tires have hardly even worn at all. Only time will tell but I can see this set getting a good 70-80K miles.
    I went with a 265/75R-16 load range E because I needed a tougher tire than the standard passenger tires, but the E range tire is a little excessive if you don't really need it. It is a little heavy weighing in at about 51 pounds too.
    Overall I have been really pleased with the tire and would recommend them to anyone who wants a good A/T that gets good traction off road, and has good manors on road. Wet weather traction is good also.
