Replacing tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma524, Apr 7, 2019.
  1. Apr 7, 2019 at 4:48 PM
    Tacoma524
    Tacoma524 [OP] Member
    Jeff
    2019 Tacoma SR
    I just bought a 2019 Tacoma SR with the steel wheels. I bought a set of 2018 TRD off-road rims to put on it. Will the tpms sensors work or do I have to buy new ones?
  2. Apr 7, 2019 at 6:50 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The steel wheel tpms is a different degree sensor than the off-road sensor. 40?, vs 20 degree's if I remember right. Some have installed steel wheel sensors 180 degree's from normal and they have worked. But tire installer has to be careful with installation of tires, so sensor doesn't get broke.
    ndoldman59 likes this.
  3. Apr 8, 2019 at 3:59 PM
    Tacoma524
    Jeff
    2019 Tacoma SR
    Are there aftermarket tpms sensors that are good or do I need to buy the ones from Toyota?
  4. Apr 8, 2019 at 4:50 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    You need OEM! Don't cheat on this!
    And don't forget you need new lug nuts! Not a simple process. Ask me how I know.
    G.
    ndoldman59, Shellshock and na8rboy like this.
  5. Apr 8, 2019 at 4:55 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    You can buy an oem set on eBay for ~$50
  6. Apr 8, 2019 at 5:07 PM
    Tacoma524
    Jeff
    2019 Tacoma SR
    Guessing you have bee through this. Thanks
  7. Apr 8, 2019 at 5:36 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I plan to get new TPMS sensors when I get new tires. Can the OEM TPMS be programmed by most independent tire shops or does that need to be done at Toyota to get the center cluster to show all 4 PSI readings?
  8. Apr 8, 2019 at 6:00 PM
    Garyji
    Gary
    I just talked to Discount Tire today because I’m doing new tires next week. They said they can do them so we’ll see. They haven’t been able to before this. I’m replacing my steel sensors with the alloy sensors so everything is correct. I had to have Toyota do mine twice to get the corner read outs.
    You can search my previous posts on TPMS to get the story. Going with Bridgestone Dueler Revo 3 in 265/65/17.
    G.
  9. Apr 8, 2019 at 9:49 PM
    bgio67
    bgio67 Well-Known Member
    2020 TRD OffRoad DCSB
    I got mine from America’s tire company (the same as discount tire) and they have been fine going on 1 1/2 years. They were cheaper than Toyota and a lot easier to work with.
    outlawtacoma and Garyji like this.
  10. Jun 3, 2019 at 3:14 AM
    Chief 4x4
    Chief 4x4 Well-Known Member
    Tim Dean
    Mississippi
    2017 TRD 4WD
    TRD GRILL WET OKLOE SEAT COVERS RAPTOR GRILL LIGHTS NEW OFF ROAD BED DECALS SCS Ray 10'S 16x8 Gunmetal OVTune
    Link??
  11. Jun 3, 2019 at 3:36 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Just go to google Type in the info, for example I entered " 2007 Toyota Tacoma TPMS" and got this for my truck.
    My 07 Tacoma sensors are still working, but I've bought sensors from Amazon for other vehicles. They are much cheaper than going through a dealer. Most tire stores will install them free if you're buying tires. They charged me $10/tire to install them after
    https://www.google.com/search?q=200...j69i57j0l4.14401j0j8&sourceid=chrome&ie=UTF-8
  12. Jun 3, 2019 at 3:51 AM
    Chief 4x4
    Tim Dean
    Mississippi
    2017 TRD 4WD
    Thanks for the info.
  13. Jun 3, 2019 at 4:33 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    I have run the rims w/o sensors. Turning them 180° sounds good at first but some shops will struggle with that request and if you get a flat its done.
