Replacing Toytecs with Fox
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FloTaco, Mar 8, 2015.
  1. Mar 8, 2015 at 5:13 PM
    FloTaco
    FloTaco [OP] Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    Quick tech question. I'm replacing my toytec coilovers with Fox 2.5s next week; in order to allow the coilovers to come out easily should I just remove the lower ball joint nut of my Desert Racing UCAs? I've done several lift kits but can't remember how I did this one. Thanks in advance. And the Toytec COs will be up for sale soon.
  2. Mar 8, 2015 at 5:16 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I disconnected my sway bar where it attaches to the spindle. Then I disconnected the upper ball joint which allows the LCA and spindle to fall away. Then unbolt the coil over and pull it out.
  3. Mar 8, 2015 at 5:26 PM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    I'm not running a sway bar any more, so step 1 complete. You disconnected the spindle from the UCA's ball joint by removing the lower nut correct? Was there any pressure on it when the nut came off?
  4. Mar 8, 2015 at 5:35 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I unscrewed the castle nut on the upper ball joint bolt until it was almost off, hit the UCA with a hammer which disengaged the taper on the ball joint and let the nut "catch" the pressure. Then unscrewed the castle nut the rest of the way.
  5. Mar 8, 2015 at 5:39 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    first thing... lower ball joint... and UCA are not the same thing.
    You can undo the lower ball joint on the LCA (lower control arm) via the 2 bolts that hold it to the spindle, Mark the alignment tabs, loosen the LCA bolts at the fram and the whole assembly will drop out so easily you dont even need a spring compressor.
    this is the way i would do it.
  6. Mar 8, 2015 at 8:00 PM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    Thanks, my terminology while typing didn't transfer. I meant the lower nut OF the UCA ball joint. I'll give your LCA method a shot.
