Replacing Transmission - 2017 off-road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zli96, Dec 20, 2022.
  1. Dec 20, 2022 at 6:38 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I may be way off base... I see no actual Diag info on that repair order... I remember my old Taco having a shudder- was the carrier bearing.
    Chew likes this.
  2. Dec 20, 2022 at 6:45 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Needle bearing doesn't cause a shudder. it's an on and off vibration while driving.
    Tacomaryan18 likes this.
  3. Dec 20, 2022 at 6:48 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    Seems more like a shot in the dark guess from a dealer trying to make a big sale. Def get a 2nd opinion. Good luck!
    Chew likes this.
  4. Dec 20, 2022 at 6:50 AM
    Zli96
    Zli96 [OP] Member
    Central North Carolina
    Thanks guys. Hoping the second shop (transmission only) will have better news
  5. Dec 20, 2022 at 6:53 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The torque converter shudder seems to be affecting some of the older 3rd gen tacos. The transmission isn’t the issue. Replacing the converter fixes it. Try adding some lubeguard shudder stop. Stuff worked wonders in my buddies taco
    50Buck, Zli96[OP] and TS4x4 like this.
  6. Dec 20, 2022 at 7:08 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Yeah I'm aware. Just wanted to cover every base in case the mechanic didn't know all of the Tacoma's quirks and potentially misdiagnosed it. But it looks like it's a moot point since OP doesn't have a lift.
  7. Dec 20, 2022 at 7:39 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    I have a solution to your problem,,,GET A MANUAL. Sorry I had to say it.
    kyhillbilly55 likes this.
  8. Dec 20, 2022 at 7:40 AM
    Zli96
    Zli96 [OP] Member
    I would have if they offered a dclb
  9. Dec 20, 2022 at 8:05 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Did you ever service your transmission or is it the original 5 year old fluid with 130k miles?
  10. Dec 20, 2022 at 8:07 AM
    Zli96
    Zli96 [OP] Member
    Was serviced at 30k when I bought the truck and then again but I can’t remember when
  11. Dec 20, 2022 at 8:23 AM
    kyhillbilly55
    kyhillbilly55 Active Member
    Tacoma 2022 TRD sport
    almost impossible to find MT these days.....only 5% of the Tacoma's are MT....and a 6 speed only at that....seems weird having that sixth gear.
    i had a similar problem with my 2006 2nd gen.....was told the rear end was going out...$1000 later and the vibration was still there.....so i jacked it up and pulled the drive-line myself.....it was a seized universal.....$35 at advanced...
    Just Say'n
  12. Dec 20, 2022 at 8:26 AM
    maxmk8
    You may want to try and service it again but... it is a crapshoot... shudders usually point to a converter on its way out or bad fluid or both... but the fluid may help... But make sure Toyota OEM only fluid is used.
    Zli96[QUOTED][OP] likes this.
  13. Dec 20, 2022 at 8:28 AM
    maxmk8
    No it isn't. Easier now than pre Mexican Beer. Plenty of tacomas on the lots now. And discounts are back too... I couldn't find a TRD pro in manual back in 2020... however scored one in 22. And there are MANY 23s at sticker around also... in manual.
  14. Dec 20, 2022 at 10:27 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i doubt the transmission or torque converter is bad. but it's possible.
  15. Dec 20, 2022 at 11:04 AM
    #35
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    At least they will be able to save and reuse that lifetime fluid.
    auskip07 likes this.
  16. Dec 20, 2022 at 11:34 AM
    #36
    sethstacoma
    sethstacoma Well-Known Member
    Seth
    2022 Toyota Tacoma TRD O/R 6spd manual.
    I'm thinking it's a bearing or driveshaft related, torque converter shutter feels like hitting rumble strips when it shifts. If it's not throwing codes I would have someone inspect the driveshaft while in neutral.
    Zli96[OP] likes this.
  17. Dec 20, 2022 at 4:24 PM
    #37
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Let me know when the part out commences
  18. Dec 20, 2022 at 4:28 PM
    #38
    MGMDesertTaco
    If the trans really is defective I'll bet you could find one out of a totaled truck for a lot less. If you choose to let a shop do the work most of the cost will be labor.
    shakerhood and Zli96[OP] like this.
  19. Dec 20, 2022 at 5:05 PM
    #39
    Zli96
    Zli96 [OP] Member
    What do you mean?
    cryptolime likes this.
  20. Dec 20, 2022 at 5:06 PM
    #40
    maxmk8
    He is just thinking you’ll flip the truck and wants to get first dibs on the parts
