Replacing Transmission Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rogerkamp8817, Mar 6, 2013.
  1. Mar 6, 2013 at 9:56 PM
    rogerkamp8817
    rogerkamp8817 [OP] Well-Known Member
    Orange County, California
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    I'm at 45k miles now and I'm planning ahead on getting my transmission fluid replaced around 60k miles.
    I searched and it seems pretty tedious. The transmission has to be at the right temperature for you to fill up the fluid properly.
    My questions are:
    1) I'm thinking I should just bring it to the dealer. How much will this cost? I'm estimating about $300-$400. Could this be done for less? I'm in Orange County, CA. If you're local, do you have any recommendations where I can get this done properly for a good price?
    2) Why can't I simply drain the fluid, measure exactly how much (i.e., fill it up in a milk gallon jug), then proportion the amount of new transmission fluid in a 2nd milk gallon jug to the exact same level, maybe a hair more just to be safe and pump that into the transmission? Would this be difficult? I wouldn't even have get the temperature right or anything if I'm simply putting back the same amount that came out. Am I over simplifying this process? Is it not worth the risk of messing this up and ending up with a catastrophic failure of the transmission?
    Thank you.
  2. Mar 7, 2013 at 12:46 AM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    because there's something like 12 quarts in the whole system and the tranny pan only holds 3... thats only 25% of the stuff you're replacing.
    i might be picking up a bunch of toyota t iv oil soon. i'll let you know the price if you need it.
  3. Mar 7, 2013 at 1:38 AM
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    My dealer quoted me $170. I am typically a do it yourselfer but with the tranny it’s a different story. Too much oil and you blow a seal, not enough oil and you burn it up. I am just planning on having the dealer do it. IMO
  4. Mar 7, 2013 at 2:10 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    I think for 150-170 I'm going to the dealer too. 12 quarts at 6-7 dollars per qt is already 80-90 bucks after taxes.
  5. Mar 7, 2013 at 2:14 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Don't let them fool you, all the dealer is going to do is drain and fill, for $170.
  6. Mar 7, 2013 at 7:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have a 2nd Gen and an Automatic.
    The Transmission fluid doesn't need changed until 100K miles - and that's per Toyota.
  7. Mar 7, 2013 at 11:28 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    That fluid is 100,000 mile rated... My 2005 was done at 100,000 miles, never any issues... other than I traded it in for my 2010, at 102,000 miles! LOL
  8. Mar 7, 2013 at 12:28 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    ^^^^^THIS^^^^^
    Not sure why people think dealer will do anything else. There is no flush machine for new transmissions. So at best dealer will do drain and fill at worst will do nothing and still charge you.
  9. Mar 7, 2013 at 12:47 PM
    xyourlocaldjx
    if they are doing a drain and fill for 170 that's a sick deal. better double check first
  10. Mar 7, 2013 at 1:16 PM
    PRIMETIME
    PRIMETIME Well-Known Member
    Albuquerque
    06 DCSB SPORT 4x4
    Did mine in my garage, pretty sure i got 15 qts out of it. Wasnt hard at all.
  11. Mar 7, 2013 at 1:53 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I went in to have mine flushed at 60000 miles and after the dealer agreed to do it, they called me back and left a message stating that they were only going to do the drain and fill due to something about the machine. Not much difference in price though.
  12. Mar 7, 2013 at 1:56 PM
    Manwithoutaplan
    ID
    I would advise a flush over just drop and add, Especially on a transmission.
  13. Mar 7, 2013 at 3:48 PM
    xyourlocaldjx
    doesnt the diy say its 12quarts?
  14. Mar 14, 2013 at 12:46 PM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    I asked my dealer yesterday when i was in for oil change. They said they have a machine that flushes the whole system about 12 quarts. They said the change runs just under $200 due to the cost of fluid. I would rather pay that then mess something up.
  15. Mar 14, 2013 at 5:07 PM
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    thank god I got 6 spd tranny
  16. Mar 14, 2013 at 5:18 PM
    xyourlocaldjx
    What dealer is this? 200 seems fishy. The fluid alone is over 100 from factory.
    Number you ain't in California
  17. Mar 14, 2013 at 5:38 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Interesting , my '09 Canadian Tacoma maintenance schedule calls for replacing the automatic transmission fluid at 96 000kms ( 60 000 miles ) , and I had this done yesterday , and indeed my invoice shows a complete transmission fluid flush and replacement with 12 units ( I assume litres ) of synthetic ATF , the flush was explained to me by the service manager as well as the tech that always works on my truck
    I guess I'm just not paranoid enough to believe they just didn't bother , but wrote it up and took my money anyway
    Oh and cost was $137 parts and $95 labour
  18. Mar 15, 2013 at 6:31 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    What ^^ he said. around ~200 for flush. But I will have them show me the process when they do mine.
  19. Mar 16, 2013 at 9:18 PM
    BamaToy1997
    Bill
    Navarre, FL
    No basis in truth here. Dealerships are a far cry from what the general public makes them out to be. Every dealership I have worked at would do a full and proper flush with a machine, or if the machine was not working, we would tell the customer so, and reschedule the service.
    You have to realize that the dealerships do not buy transmission fluid by the quart for the service department, normally. (Though it is done on rare occasions) They buy it by the hundred gallon lots, to be dispensed by the same way oil is for oil changes: Pipes and hoses in the shop. That Toyota transmission fluid that costs you say $6 per quart, costs them about $1.50 at best when they buy in bulk gallons. So 12 quarts of fluid costs them around $18. (Note that this is an estimate based on when I was working at the last dealership I was at) And then they charge you based on standard markup. Sometimes it may be that $6 per quart, but usually it is less. Plus labor charges. All of this is to pay for the tech working on your truck, the fluid itself, and cost of the machine plus wear and tear. Then the rest is profit. As I recall our full flushes were $189, and profit was about $30.
    We had the basic PF-5, but this video shows the newer one. If you notice near the end of the video, the upper sight glass shows very dark fluid from the truck. After service is done, it is pinkish-red again.
    http://www.youtube.com/watch?v=CrYCmQONfNs
  20. Mar 16, 2013 at 9:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Did anyone ask the OP if he has a 2.7 or a 4.0?
    The 2.7 still uses T-IV. 4.0 takes the WS which is the 100k rated fluid.
