Replacing u-bolts with AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DirtJumper14, Jan 29, 2009.
  1. Jan 29, 2009 at 10:27 PM
    DirtJumper14
    DirtJumper14 [OP] Well-Known Member
    I have heard before that anytime you change around the leafs or whenever you loosen the u-bolts that you should replace them. because of the wear and stress on them. I am doing the 5100 and AAL in a day or 2. Anyone have an opinion of this? Gonna do it this weekend so wanted to ask, thanks guys
  2. Jan 29, 2009 at 10:28 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Mine are the originals, they work fine, no need to replace
  3. Jan 29, 2009 at 10:35 PM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Only replace them if you need more length. After a week, get back under the truck and make sure the nuts are still tight. Other than that, there's no reason to get new U bolts. (unless of course you read the replies below me and figure out that I don't actually know what I'm talking about...)
    Rob
  4. Jan 30, 2009 at 7:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Technically, You should replace the "U" bolts, as once they are torqued down, they stretch. I have reused them before, but I would only reuse them one time, then replace.
  5. Jan 30, 2009 at 7:11 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    Once they stretch and you re-use them, they have a tendency to come loose. When the u-bolts come loose - usually causes the centering pin head to sheer off. When the centering pin head sheers off....it can get really ugly.
    I'd highly recommend getting new ones.
  6. Jan 30, 2009 at 7:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, Im takeing that you have sen this too? "Ugly" is the PERFECT word. ;)
  7. Jan 30, 2009 at 7:21 AM
    Janster
    Jandy
    Lancaster, PA
    Ohhh yeah.... far too many times. Never happened to me though.... I'd rather spend the money up front and prevent the headaches later. ;)
  8. Jan 30, 2009 at 7:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    x2! :)
