Replacing U-Joints: Write Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jangel2, Aug 23, 2013.
  1. Jul 26, 2017 at 1:32 PM
    #41
    Krusey1011
    Krusey1011 Well-Known Member
    Kyle
    Washington
    I've been shimmying. I hit it with a rubber mallet a few times as well. I did have it in 4wd and didn't turn it off until after I had stopped, maybe that could have something to do with it.
  2. Jul 26, 2017 at 1:39 PM
    #42
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Mines a prerunner so its 2wd. I know 4wd's have a slip yoke, this being the main difference in the (rear) driveshaft. Maybe it has something to do with this? Sorry I cant be of more assistance. Good luck!
    Krusey1011[QUOTED] likes this.
  3. Feb 8, 2018 at 8:25 AM
    #43
    panthertaco10
    panthertaco10 New Member
    Benjamin
    2010 Black Tacoma
    TacoTuesday!! likes this.
  4. Feb 8, 2018 at 9:49 AM
    #44
    BassAckwards
    For the rear driveshaft i believe there is 3, but there are 2 on the front driveshaft, so 5 total for a 4wd
  5. Apr 2, 2018 at 8:03 AM
    #45
    dino velvet
    dino velvet Member
    San Antonio, TX
    07 Prerunner sr5 TRD
    Great thread, going to be changing out my U joints on my prerunner this week, ordered the Spicer 5-1330-1X so waiting for them to arrive and get my ducks in order with a U joint press, grease, etc.
    One question I have is does it make a difference if your transmission is in Park or Neutral? I will be chocking all 4 wheels but was wondering if having it in neutral would make pulling the driveshaft out of the transmission easier?
    Thanks
    BassAckwards likes this.
  6. Apr 2, 2018 at 8:08 AM
    #46
    BassAckwards
    Its not going to make a difference if the wheels are on the ground. The only thing it will do is spin if theyre up in the air. Pulling the driveshaft out of the tranny shouldnt be too hard, just start at the rear diff and then work your way forward. Obviously reinstalling it is going to be the complete opposite. Make sure you mark the drive shaft with a paint pen or sharpie so you get it put together the same way so its balanced
  7. Apr 2, 2018 at 8:10 AM
    #47
    BassAckwards
    Also, i noticed your in san antonio, i am about an hr and a half west of there if you end up needing help with this
    tacofor4 likes this.
  8. Apr 2, 2018 at 9:28 AM
    #48
    dino velvet
    dino velvet Member
    San Antonio, TX
    I appreciate the offer and reply, it seems pretty straightforward with the right tools. Any reason why someone would replace the center support bearing as well at the same time if it doesn't have play?
  9. Apr 2, 2018 at 9:44 AM
    #49
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    A paint pen is what you need too use for marking on the driveline.
  10. Apr 4, 2018 at 11:31 AM
    #50
    dino velvet
    dino velvet Member
    San Antonio, TX
    I've got a tube of Lucas X-tra heavy duty grease I was going to use to fill the Zerk fittings on the U joints, is this a good grease or is there something others are using in their U joints?
  11. Jul 29, 2018 at 10:12 AM
    #51
    bj4203
    bj4203 Member
    2010 Toyota Tacoma TRD
    I have had the same problem, driveshaft wont come out of the transmission. What did you do to get it out?
  12. Aug 11, 2018 at 10:43 AM
    #52
    Krusey1011
    Kyle
    Washington
    Sorry, just seen this. I just unbolted it. This reminds me though. I received a letter from the dealership pertaining to u joints. They’ll replace them or cover the cost of past repairs.
  13. Aug 11, 2018 at 10:58 AM
    #53
    bj4203
    bj4203 Member
    Ya I knew that and had contacted toyota about it. They wont touch it on account of lift on my truck.
