replacing u joints
Discussion in 'Technical Chat' started by Ptowntaco, May 9, 2011.
  1. May 9, 2011 at 1:14 PM
    Ptowntaco
    Ptowntaco [OP] Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    I have a 2000 prerunner an my u joints are bad. There is a good clunk when going from reverse to drive or drive to reverse.
    My question is do i need to have my drive shaft re-balanced after i replace them or can i just replace them an be good?
    Thanks Bryce
  2. May 10, 2011 at 6:15 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    There is no rule to that, but... when you replacing them make sure you keep those locking tabs the same way as they were on old u-joint. Those locking tabs are what sets u-joint for shaft to be balanced. So before you remove old u-joint mark everything . Drive shaft and each locking tab. If you do that most likely there will be no need to balance. if you don't then you going have to get shaft rebalanced.
  3. May 10, 2011 at 11:09 AM
    Ptowntaco
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    there is vibrations when i drive also i left that out sorry
